Neck Shim
Discussion in 'Tele Home Depot' started by Mark the Moose, Dec 8, 2019.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    I need to shim a bolt-on neck and I'm hoping to avoid at least some time-consuming trial and error. I've narrowed to three options, but I'm open to suggestions. FI: I'm a seasoned wood worker.
    1. Order the stewmac shim and pay the stupid high shipping cost. Not inclined but could be my last resort.
    2. I have a crap ton of oak veneer left over from another project I could cut pocket sized pieces each a little shorter than the previous so they step up...then glue and sand.
    3. I use a miter saw with a finish blade set at .5˚ or 1˚ to cut a wedge off the end of a board.
    4. ???
    PeterUK likes this.
  2. tubelectron
    tubelectron Tele-Holic
    France
    I had to shim evenly (no angle) the neck of my Harley-Benton JA60-LH-OW "Tempest" to accomodate the installation of a tremolo and roller bridge :
    I used a flat aluminium plate cut and drilled to size. No glueing :
    But it's me, OK ? :D
    -tbln
    DonM, Zepfan, crazydave911 and 3 others like this.
  3. guitarbuilder
    Use a piece of business card about 2 x .75" long or (cereal box stock) at the back of the pocket. I clip off the back corners at 45 degrees to fit into the corner. Use two if you need to but one usually does the trick.
  4. rangercaster
    portland, or
    Depending on size needed, I have heard of everything from business cards, credit cards, pieces of veneer ... The idea of ordering, buying and shipping seems excessive to me ... I'll let the experts chime in ...
    EsquireBoy likes this.
  5. tele_savales
    tele_savales Tele-Meister
    Brooklyn, Joey!
    Buy an expensive, must-have tool from Stewmac to make the shipping worthwhile. There HAS to be something you can't live without in their catalog.
  6. Tommyd55
    Tommyd55 Tele-Meister
    Southern Louisiana
    I use to use business cards but I have since gone to using the StewMac shims. Yeah I think they are over priced and their shipping is wack.. I do not order much from them unless it is necessary.. Usually a specialized tool if needed.
    The guitars I have now are my keepers, I have one more pcaster to go to be set.. I think.. how many people here have said that line..
    But I broke down and bought all the shims I needed for my collection plus a couple of extras. I like to have a little back angle on my necks for various reasons. The Stewmac shims, as over priced as they might seem to be, are, at least imo, the best option giving you precise control over the job.
    Their shim's are pretty thin which is good as that adds little overall to the height of the neck in the pocket. I usually use their .25 or occasionally a .50. I guess the main consideration is what it is you are trying to accomplish.
    For me I decided the effort for me to produce anything as good as their shim well, it just makes their shim seem not so over priced in reality.
  7. Ronkirn
    Jacksonville, FL
    you do NOT want the shim to be the full size of the neck pocket.. doing that would require a thicker shim than if you just cut a piece of the veneer about ½" x 2". The angle it imparts on the neck projects the resulting string location above the bridge high enough to allow for the increased height the Bigsby setup requires...
    rk
    beagle, gkterry, Ricky D. and 2 others like this.
  8. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    A business card is made of paper. Paper is made of wood. Wood apparently gives some people a good feeling about tone. So use a strip from a business card.
  9. Chunkocaster
    In space with Ziggy
    A credit card fits perfectly in the neck pocket after trimming a small amount off the front edge. That small amount could be added to the back of the pocket to create a angle if required.
    Boil likes this.
  10. Bob M
    Bob M Tele-Afflicted Ad Free Member
    North of Boston
    For guitars I need to shim i use a piece of aluminum flashing. The thickness is just right and as Mr Kirn suggests you don't need a shim the size of the entire pocket. I believe your goal is to adjust the angle, not the height of the entire neck. I cut a piece no more than 1/2 inch wide, the width of the pocket.
  11. Mark the Moose
    Erie, CO
    Thanks all, I *think I need an angled shim. Basically the bridge and saddles are bottomed out the but the action is still too high up the neck.
    Some inter web posters caution against air gaps as a speed bump at the end of the neck can develop. Anybody verify?
  12. guitarbuilder
    Consider the fact that CBS era guitars had a tilt adjust mechanism which was just a bolt touching a plate. If that causes a speed bump, then half a million guitars must have it.
    https://www.fender.com/articles/tech-talk/how-micro-tilt-majorly-affects-your-action
  13. fendrguitplayr
    fendrguitplayr Poster Extraordinaire
    Greater Boston
    I've used folded "post it" notes to shim. Sometimes it doesn't take much.
  14. Ronkirn
    Jacksonville, FL
    And a little known factoid... the Micro Tilt was Leo's creation... it was destined to be part of the guitars if Leo had sold to CBS or not... And during Leo's tenure, Leo used stamped steel shims... they were the width of the neck by about ½ inch...
    and you do Not need an angled shim. it's a solution for a nonexistent problem..
    r
    beagle, gkterry, howardlo and 3 others like this.
  15. Tommyd55
    Southern Louisiana
    Don't think this shim will be detrimental to the over all picture.
    Of course if your cutting shims with a DeWalt circular saw freehand you might have some issues..
  16. Freeman Keller
  17. schmee
    I use the clear plastic that is on packaged items. It seems to come in .005 and .010 thickness. I just save pieces for use when I need it. Sometimes I use two layers of the .005 like this picture. But I don't think it matters much. .010-.015 is a lot of shim and changes the string level quite a bit. BTW, I have never had to shim the end shown in my picture here. It's always the headstock end. Yet, Fender puts their "tilt adjustment" screw in this end.
  18. Boil
    Boil Tele-Holic
    B.C.
    Along with being cost effective you have the added bonus of saving large amounts of money by not being able to just pull it out of your wallet at the local music store, takes me about half an hour to get my card out to buy anything now.
  19. JeffBlue
    JeffBlue Tele-Afflicted
    Southern California
    I like using thin metal shim stock preferably brass.
    That Cal Webway likes this.
  20. EsquireBoy
    EsquireBoy Tele-Holic
    Paris, France
    Another web myth. A "speed bump" can indeed develop on a bolt-on neck design, but it's due to the neck architecture (the heel is substantially thicker, so it's less prone to bend IF the rest of the neck is developing a bow), and it's often when stress is caused by over-tightening the bolt screws.
