Neck Pocket Too Deep..what Are My Options?
Discussion in 'Tele Home Depot' started by czech-one-2, Mar 9, 2016.
  1. czech-one-2
    czech-one-2 Friend of Leo's
    East of you
    Hi folks, I'm putting together a parts-tele with Fender mim standard neck and a one off body that I won on ebay. I've got it together and the four neck bolts even matched perfectly, however even with the saddles at there lowest the action is a bit too high and its hard to get rid of the string buzzing. It plays ok as is, but not what I was hoping for. :(
    I've tried shimming the neck heel and the taper from low to high gets better, but string buzz worsens.
    Then I decided to measure the neck pocket and its 76mm long which is correct, but its cut 19mm deep, while a fender or warmoth neck pocket is 16mm deep.
    This puts my neck too low and the saddles,at there lowest, too high.
    Can this be repaired/salvaged? Do I have to glue in a flat 3mm piece of wood into the neck pocket??? Will that work?
    The body was made by an Austrian violin/guitar builder student and was their first project. It is a beautiful looking body of maple with a black limba top and sonically the guitar sounds very nice. But I need to sort out this problem or it is not going to be my main player...
    [​IMG] [​IMG]
  2. Count
    Count Friend of Leo's
    Tenterfield, Australia
    That would seem to be the obvious solution but do a dry run first. That is, put a 3mm piece in without gluing it to see if solves the problem. Be careful of your screws though as they will be reaching 3mm less into the holes, there should be no problem just tighten them carefully.
  3. kwerk
    kwerk Poster Extraordinaire
    New Zealand
    Yep, 16mm is what it should be. The 3mm spacer will do the trick nicely. You don't even need to glue it. Make sure the holes you put in it are large enough for the screws to pass through freely.
  4. czech-one-2
    East of you
    Thanks for the reply. Yeah, I guess thats the only possible solution but its kind of a bummer. I was hoping for my ultimate tele...
  5. czech-one-2
    East of you
    Well Kwerk, that sounds encouraging at least!
    I just took the neck off and measured the pocket depth and its 20mm, not 19 so I need a 4mm shim. Is this getting ridiculous or can this be done?
  6. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    It's going to turn out great. It may be so good, we will all route our neck pockets 3 mm deeper and put in spacers like yours. Expect the best ,my friend, the best.
    Seasicksailor and Peltogyne like this.
  7. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    Thinner saddles ?
  8. kwerk
    New Zealand
    It's absolutely fine. Remember, all you're doing is making the pocket the depth it's supposed to be. There's plenty for the screws to grab, because all you're doing is making the pocket into what it shpould be. Just use the neck heel to pattern the insert, make it slightly longer than it needs to be, put it in there and tighten the screws up. if it's sitting happily, use the front of the neck pocket as a ruler to mark where it needs to be cut. Make your cut, reassemble and you're golden. If you're happy with the fit, you can even glue it in if you feel the need, but the screws will hold it plenty tight enough.
  9. guitarbuilder
    There's nothing wrong with a shim. Stewart Macdonald started selling them. Once it is in there you may not give it another thought. The shim controversy is another one of those unproven tone debate items that nobody can seem to substantiate scientifically.
  10. czech-one-2
    East of you
    You guys are great! Thanks for the encouragement cause I was getting a bit bummed.
    As a temporary fix attempt I just put a metal neck plate with its plastic back [about 3.5mm] inside the neck pocket and bolted her up. Now we're talking! Easy buzz free action!
    So it can only get better with a proper shim cut. I'm not much of a woodworker but this can't be to hard.
  11. czech-one-2
    East of you
    You know, I was even contemplating fileing them down on the bottom. Glad I didn't cause 4mm is an awefull lot!
  12. Charlie Bernstein
    Augusta, Maine
    Try wearing a turtleneck.
    czech-one-2 likes this.
  13. ItchyFingers
    ItchyFingers Tele-Afflicted
    Ottawa Ontario Canada
    It happened to me on my last build. I got a bit rushed and yeah, the saddles were too high.
    I put a plastic shim under the neck with every intention of repairing it properly.
    That was 3 years ago. I haven't changed a thing since it is the most wonderful guitar I ever had my hands on.
    I don't want to mess it up by fixing it. It's not going to be sold or anything (ever) and so I will simply enjoy my littler shimmer.
  14. czech-one-2
    East of you
    Yeah, fortunately I bought this with no intention of selling it. Actually, I plan to put a bigsby on it and keep it forever. :cool:
    It was actually made by a female lutherie student, and she did a nice job. Real clean routing throughout.She said she used a 52' tele template, maybe her drawing had a 20mm depth?
    I cant complain though cause the body was complete [sans EMG pickups] and it was cheap!
    Its even a chambered body so this guitar is very light indeed.
  15. Mojotron
    Mojotron Poster Extraordinaire
    Seattle
    You may want to try a 2mm-3mm square shim made out of hard plastic or maple and just shim the back of the heel - closest to the bridge. That creates a slight neck angle, but a tele actually benefits from a slight neck angle - could make a great guitar actually better with more break angle on the saddles and a little more ergonomic playing angle.
    I_build_my_own likes this.
  16. Preacher
    Preacher Friend of Leo's
    Big D
    When you put a bigsby on you will need a slight taper neck shim. The standard is 4mm thick at the heel with a taper to 0mm so you will be putting an even thicker shim in there. I would cobble one out of maple for the density and the match of the neck.
  17. czech-one-2
    East of you
    I dont think I'll need to taper the shim for a B5 type Bigsby, just notch the bridge. But we'll see. I need to find a used B5 over here in the EU cause new they are getting outrageous, $170.00 + :eek: [Thats almost as much as I have into this guitar. Anyway, the good news is I made a 4mm thick maple shim today, and this guitar plays like a dream. Really the lowest action of my 3 guitars and no buzzing anywhere. I think it helped hearing from you guys first, gave me a positive attitude making the shim knowing it wasn't a lost cause. Really happy with the result!
    kwerk likes this.
  18. Mojotron
    Seattle
    I do stuff like that - play it for a few years and completely forget about any mods I made
  19. czech-one-2
    East of you
    Not even that ugly!
    Seasicksailor likes this.
  20. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    just wondering what this has to do with anything. We've got at least one female builder on the board here, she does incredible work-- complex designs, inlay, and finishing are all top-notch.
