Neck Pocket size..??
Discussion in 'Tele Home Depot' started by JerKap, Sep 20, 2009.
  1. JerKap
    JerKap TDPRI Member
    Iowa
    I plan on putting a Mighty Mite rosewood neck on a Squire Fat Tele.
    So I took off the Squier neck ,, to check the pocket size.. I'm using the info that Stewart-Mac has on they web site,
    (I think they sell MM necks).
    http://www.stewmac.com/shop/Bodies,...:_Necks/Replacement_Neck_for_Tele_Guitar.html
    The only measurement on my pocket that is different is depth of the pocket.
    My body's pocket is 18.45mm, or 13/16,, Is this depth OK for MM neck..??
    Stewart-Mac info has 15.88mm or 5/8 ..
    Thanks for your help..
  2. Prius
    Prius TDPRI Member
    The Netherlands
    Normal pocket depth is 5/8" (1.5875cm). 2.6mm off can be problematic, depending on the thickness of the neck.
