Neck pocket routing video
Discussion in 'Tele Home Depot' started by plook, Dec 3, 2012.
  1. plook
    plook Tele-Meister
    Sheffield, UK
    Can anyone point me towards any video of the Tele neck cavity routing.
  2. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    I'm not aware of a video but this thread will show you how to make a neck pocket template. This technique can also be used to rout the pocket directly without a template.
    ** Making A Neck Pocket Template **
  3. guitarbuilder
    Routing is routing. The tele neck cavity is a tapered rectangle that is nominally 5/8 "deep with the end corners by the neck cavity having a 1/4" radius. That means use a 1/2" diameter pattern routing bit. You can remove the bulk of the waste on a drill press with a forstner bit and just use the template to clean it up and look professional. Any video that shows routing a guitar cavity would utilize the same techniques whether is be control cavity, pickup cavities, or neck cavity.
  4. mojoatomic
    mojoatomic Tele-Holic
    Horn Lake, MS
  5. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    You can see the procedure Guitarbuilder has analyze, at this video :
    http://www.youtube.com/watch?v=Rus_GtHqOLM
  6. plook
    plook Tele-Meister
    Sheffield, UK
    Thanks for those, very helpful. Terrified of the router, tends to get away.
    Monkeyking, that one is perfect because he uses the template i have borrowed but didn't really know how to use. i can see i hold it down with double-sided tape. Thanks so much!!
  7. TRexF16
    Tucson
