Neck plate - Squier versus Fender American
  • Thread starter Sequimite
Sequimite
Sequim, WA
The plates themselves are functionally identical. My first partscaster had a Fender neck plate and there was no difficulty attaching the neck to the body. For my second I had a Squier neck plate and broke off the last screw. the neck plates themselves seem functionally equivalent but the Squier screws should be thrown away.
As you can see in the photo the Squier screws are narrower and slightly shorter. The Fender screws are not only more robust but they come with waxy lubricant on the threads.
john_cribbin
London
Some of the Asian screws seem to be made out of something akin to cottage cheese. I've been replacing some of mine, mainly saddle grub screws with stainless steel ones. Peace of mind for a few pennies.
3-Chord-Genius
Winchester, VA
Why do I only see that black plastic thing on the neck plates of cheaper guitars? I'd think it would be a good idea for all guitars, but what do I know?
bobio
Here
Have you noticed the weight difference between the two? Fender has started making some neck plates out of aluminum.
The American Performer neck plates are aluminum and I have a couple of American Professional plates like the one shown above that are also aluminum.
I am in no way saying this is an issue you should be concerned about, just a curiosity I noticed recently. I confirmed it with Fender.
Boreas
Adirondack Coast, NY
Wouldn’t plastic be more prone to softening in heat and hardening in cold and thus changing, even slightly, in different environs? Not sure I’d want that.
(link removed) (link removed)
Possibly because they don't have to plate them. Chrome plating is a nasty process.
