Neck plate for Indio Tele
Discussion in 'Other T-Types and Partscasters' started by AbleMob, May 7, 2021.
  1. AbleMob
    AbleMob TDPRI Member
    Central Jersey
    Anybody know where I can get a gold neckplate for an Indio Tele? It's an odd size, slightly smaller than Squier or standard Tele specs. The distance center to center of the screws are about 1/8" less than the other standard ones.
  2. dan1952
    dan1952 Friend of Leo's
    Anderson, IN
    What exactly is an Indio Tele?
  3. TX_Slinger
    TX_Slinger Tele-Meister
    The Sticks, TX
    its an ebay tele. Not a bad tele to practice doing fretwork on. Op, try ebay for "Asian pattern neck plate."
  4. NilsZippo
    NilsZippo TDPRI Member
    Austin
    Indios are actually sold by MonoPrice and as TX_Slinger said their entry level guitars can be very good guitars to learn to do stuff on like fret leveling, setup, electronics overhaul. MonoPrice now sells a newer better version of their Tele styles that are very good. Somewhere between a Squier Bullet and a CV series in terms of quality.
    To answer the OP, you will probably need to make your own neck plate.
  5. JrRalphio
    JrRalphio TDPRI Member
    Los Angeles
    You should try painting the one it came with and polishing it should come out nice if you do it right I got the same indio i scrapped the paint off the body spray painted it and put a maple neck playing amazing was thinking about putting new pickups but i kinda like the crunchy sound they came with sounds real grungy
