Neck Pickup Cover Change
Discussion in 'Telecaster Discussion Forum' started by watchoutitslucas, Aug 1, 2021.
  1. watchoutitslucas
    watchoutitslucas TDPRI Member
    Miami, Florida
    Hello,
    So I got a pair of fender pure vintage '64 and i need to change the pickup cover on the neck pickup. I just wanted to know if anyone has tips or how to do it correctly. I don't want to mess up the pickups and I know there is a solder joint in the single tab where the wires go.
    Thank you!!
    Fendereedo and Boreas like this.
  2. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    Just checking, are you sure you want to take that step and lose your pickup’s protection from physical damage and electrical shielding (noise)? I’ve done it and like it, but it’s more work to undo it if you change your mind. And novices at soldering who might otherwise buy it, might not want to buy it second hand after it’s been modified by you.
    Tonetele and Fendereedo like this.
  3. watchoutitslucas
    Miami, Florida
    Well its a kit guitar and I want the aesthetic to look the same since I'm doing black and gold. this guitar and pickups are not going to be sold since its a guitar I'm building for me.
  4. Antoon
    Antoon Tele-Afflicted
    Low Lands
    Mind that you bend the three tabs fully flat/straight before pulling the cover from the pickup. You also may heat up the pickup with a hair dryer or heat gun in order for any wax to melt. Sometimes the cover is fixed by the wax.
  5. SnidelyWhiplash
    SnidelyWhiplash Friend of Leo's
    Hoggtown, KY.
    Sounds like a nice recipe for a damaged/dead pup... :cool:
    Pcs264, Fendereedo and Phrygian77 like this.
  6. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Silver Supporter
    Oregon Coast
    I would just buy a neck pup with exposed poles (or wind your own), save the effort, & mitigate the risk of killing your original. I was once planning on swapping a chrome cover out for a black one, & decided that there was a higher chance of wrecking the pickup than of success.
    Fendereedo and watchoutitslucas like this.
  7. watchoutitslucas
    Miami, Florida
    Yeah i think im going to keep it chrome for now its would just look so cool all black and gold hardware.
    Fendereedo likes this.
  8. Old Deaf Roadie
    Oregon Coast
    Many folks don't like black & gold, but it works on my Ess-Kwire build pictured below. This is pictured before I nodded as an Esquire & is the neck pickup I wanted to swap covers on. The black binding pulls the look together on the cream body. The pup is a GFS P90 that came with the pearl top.
  9. watchoutitslucas
    Miami, Florida
    beautiful!!1
    Old Deaf Roadie and Fendereedo like this.
  10. Boreas
    Boreas Poster Extraordinaire Silver Supporter
    Adirondack Coast, NY
    If you are uncomfortable about performing the cover transplant yourself, you could consider having a good tech do it.
  11. watchoutitslucas
    Miami, Florida
    thought about that too
  12. Boreas
    If it gets screwed up, you have someone to yell at. But most techs will state up front that they won't be responsible for damage. But a good pickup tech should be able to swap covers. It isn't rocket science or voodoo, but is delicate work that experience helps. If you are good at fiddly stuff, give it a try. Worst case scenario, you turn your pickup into a brick.
  13. watchoutitslucas
    Miami, Florida
    i think i might just try it on a cheap pick up first, I am trying to learn as much as i can about lutherie and really want to get into it
  14. yegbert
    Maryland (US)
    Another thing you might consider is first practicing doing this on a different pickup, one broken or otherwise of negligible value. Just remember that one you or someone else had removed before, you or someone else might later want to try. I had at one time pulled the original ceramic pickups out of a ‘98 Squier to try some others, and I recently put those pickups into a Tele to try, and have decided they sound good to me!
    Edit: I was making this post while you had typed the one now just before this, I see you already had the idea to practice on a cheap one!
  15. Fendereedo
    Fendereedo Poster Extraordinaire
    Sunny Suffolk UK
    I would leave well alone, as the PV 64s ain't cheap, well they're not where I live anyway. Unless you are 100% certain what you're doing.
    watchoutitslucas likes this.
  16. Boreas
    You may try going to a tech and see if they have any clunkers they can give you.
  17. Wrighty
    Wrighty Friend of Leo's
    Essex UK
    Not sure why you need to change the cover or want to remove it. Am I missing something here?
    Boreas likes this.
  18. Boreas
    I believe OP wants a gold or black cover.
  19. Wrighty
    Essex UK
    OK, not clear from the original post, thanks
  20. watchoutitslucas
    Miami, Florida
    Yeah it’s just that I’m building a tele and I want the hardware to be gold so that’s the reason
