Neck laminate question
Discussion in 'Tele Home Depot' started by Potatocaster, Nov 15, 2019.
  1. Potatocaster
    Potatocaster TDPRI Member
    Fayetteville, Arkansas
    Hi folks,
    As I'm plotting my build I've realized the stock I ordered isn't thick enough for a single piece or two piece neck. I'm now looking at laminates, but I can't find a good answer to the following:
    Is there is problem with horizontal or vertical approaches or are both fine.
    Horizontal:
    XXXXXXXYYYYYYZZZZZ
    XXXXXXXYYYYYYZZZZZ
    XXXXXXXYYYYYYZZZZZ
    VERTICAL:
    XYX
    XYX
    XYX
    XYX
    XYX
    EDIT: Basically fCe to fAce or edge to edge.
    Im looking at either stacking boards for thickness or turning them in their side. I have hard maple and black walnut to work with in this scenario.
    Sorry if this is a dumb question. Just had issues finding and answer.
  2. Jim_in_PA
    Jim_in_PA Tele-Holic Ad Free Member
    SE PA near New Hope PA
    Stacking vertical across the width will provide strength in the direction that will benefit the forces that typically affect a guitar neck. If you plan things well, you can get some very nice quarter sawn and/or figured grain across the laminations that way, too. Sacking them "flat" isn't going to be attractive normally, IMHO.
    Potatocaster likes this.
  3. Potatocaster
    Thank you! That helps considerably. I figure I can take several planks, turn them on their side, and get the width I need with ample depth. Might even alternate between woods for some visual flare.
    I ask about the stacking as I know that's done for caps on guitar bodies.
  4. guitarbuilder
    Treadplatedual and Potatocaster like this.
  5. Treadplatedual
    Treadplatedual Tele-Holic
    Indianapolis, IN
    Marty, that's an awesome example, and I have a nigh identical bass. :)
    Tater, I'm planning on trying a laminate similar to an old carvin I had with maple and walnut or something similar, but Marty's right, lll is the way to go.
  6. joeford
    joeford Friend of Leo's
    st. louis, illinois
    think about drum shells and how their laminates can bend around into those radii... you don't want the flat/skinny side running along the fretboard.
    running perpendicular to the fretboard will give you those purty stripes and be a lot more stable than a one piece
    Jim_in_PA and Potatocaster like this.
  7. I_build_my_own
    New York
    Like this:
    Jim_in_PA, E-miel and Potatocaster like this.
  8. Crafty Fox
    Crafty Fox Tele-Afflicted
    Perth Australia
    I mostly laminate my necks. This is my current, archtop, build.
  9. I_build_my_own
    New York
    And there are a few things to consider. The middle stripe should be reasonably wide so that there is enough wood left and right to meaningfully support the glue lines after you route out the truss rod channel. So don’t make it too thin. Next if you bolt on the neck you would want to dimension the 3 or 5 stripes in a way so that the screw holes don’t exactly hit the glue lines either.
  10. Potatocaster
    That looks gorgeous. My black walnut is very thin so I think I'll go for that style you have there.
