Neck humbucker in a Tele?
Discussion in 'Telecaster Discussion Forum' started by Ebidis, Jul 23, 2020.
  1. darkwaters
    darkwaters Tele-Afflicted
    Newfoundland
    That he does, and at a very reasonable price. A number of my guitar buddies have been singing his praises for years now. When I decided to install humbuckers in my Tele (Should have done it years ago!) I was thinking of a Seth Lover (Which I love!), but when I saw that Craig had something very similar, my patriotism took over.
    In my case, I've paired it with a Duncan Little '59, which Craig assured me would be just fine. It took me a few tries to match their output, but now it's perfect. Those folks who complain that neck pickups in a Tele are dark and muffled should try a Telepaf. Bright, crisp and present.
  2. Matthias
    Matthias Friend of Leo's Gold Supporter
    I never get bored of seeing that lightning bolt F-hole! I'm picturing two on a thinline Flying V now :eek:
    JeffBlue likes this.
  3. Robert H.
    Robert H. Friend of Leo's
    N. Cal.
    Lollar High Wind. I’ve tried many. This one stays.
    So now you (OP) have dozens of recommendations. Your move
  4. ndcaster
    ndcaster Poster Extraordinaire
    Indiana
    I have a Donlis DH22 (A2, 7.2k, 3.8H) in one of mine. Not too hot, but still too powerful for the single coil bridge. I put a Bill Lawrence L280TL (12k, 3.4H) in the bridge. Ah, much better.
    I'd like to try Rob's Firebird in a guitar. The clips sound great.
  5. Dobster
    Dobster NEW MEMBER!
    Cornwall , U.K.
    Hi this is the same as I want to do , would you have a wiring diagram for this setup, thanks
  6. nedorama
    nedorama TDPRI Member
    In my '85 Squier Tele, I have a Duncan Lil 59, which replaced a Strat Hot Rails Neck after it died 30 years after being installed (this was before they had a Tele Hot Rails Neck). Hot Rails in bridge; Push/pull volume tone for coil splitting.
    In my custom Gumby Tele, Duncan 59 in the neck, JB in bridge also with push/pull volume tone for coil splitting.
    Squier by Squier likes this.
  7. rze99
    rze99 Poster Extraordinaire
    South London UK
    SD Seth Lover - set low and removed from the tone
    SD mini hum. - With blended Broadcaster wiring.
    GrantR, Ebidis and boris bubbanov like this.
  8. branbolio
    branbolio TDPRI Member
    hawaii
    Didn’t know Duncan made a lil 59 for neck position??? Can you post a pic or link? Thanks!
  9. nedorama
    Ebidis likes this.
  10. reckless meanie
    reckless meanie Tele-Holic
    Bend, OR
  11. reckless meanie
    Bend, OR
  12. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    1255E402-BA86-4BFD-A131-1CE50EAA5011.png Well duh , I forgot all about the one that happens to be my avatar . A low budget partscaster with GFS Fat Pats
    It has a 5 way rotary switch, my favorite position is neck bucker and bridge single combination
    GrantR likes this.
  13. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    Here it is:
    HB:SC out of phase.jpg
    Ooops! The switch terminals are a bit wrong, but it's like a standard wiring on the switch.
  14. dougstrum
    dougstrum Tele-Afflicted
    blu ridge mtn cabin
    Tele with a neck humbucker is a classic mod for a reason.
    For my purposes I have a DiMarzio
    fastrack-1, in one Tele, and a chopper in another. Both set ups are full and clear; and silent when needed:)
  15. Flaneur
    Flaneur Friend of Leo's
    Scotland
    I have a couple I can recommend. One is the WRHB in my '76 Custom, which has been talked about endlessly, around here. The other is a Seth Lover, with the coil split facility. The single coil sounds are really sweet, unlike many others I've played. The full HB has pretty good vintage cleans....for a humbucker. :)
  16. Tonetele
    South Australia
    Am using a Tenerider A111 but would prefer a Fender 70s Widerange.
  17. Jipes
    Jipes Tele-Meister
    Mulhouse (France)
    Ebidis likes this.
  18. timbgtr
    timbgtr TDPRI Member
    Maryland
    I don’t have a humbucker in my Tele—GFS Fatbody instead—but I just replaced the HBs in a PRS S2 with Fralin Unbuckers. Highly recommended. They’re designed for coil splitting, so with a push-pull pot you could retain that single coil balance and have a fuller, jazzier but still sparkly HB option when called for.
  19. betterlate
    betterlate TDPRI Member
    Charlottesville, VA
    Missed "humbucker" subject.
  20. LizzieBennet
    LizzieBennet TDPRI Member
    Wollongong
    I have not been more impressed than my Jim Weiber Big T Fralin pickup. It transformed my guitar. Fat and punchy with attack.
    so satisfying
