loidrinkaku
Hello everyone, I got this tele body and im trying to fit a neck from another partcaster I was working on but I feel like is sticking up too much in relation with the body, I did some research and it should be about 9.5mm from the body to the top of the fretboard curve, mine is 12mm (center) and 10mm (sides), should I be worried?
The neck pocket was routed with fender specs by a luthier, it is 5/8".
Neck thickness from the middle of the heel to the top of the fretboard curve is about 26.8mm.
Before I start sanding the heel down I would like to see pictures to compare because I have no power tools and im not a fan of sanding off 2mm of maple by hand, Thanks.
