Neck bucker to pair with Dimarzio chopper T bridge
Discussion in 'Just Pickups' started by GhostofJohnToad, Sep 14, 2013.
  1. GhostofJohnToad
    GhostofJohnToad Tele-Afflicted
    Toledo, Ohio
    Thinking about swapping out the GFS noiseless in my mim tele with a Dimarzio chopper bridge and a bucker in the neck position. My main requirements are:
    1) price - under $75
    2) very good clean sound - this is most important
    3) volume wise should pair well with the chopper
    Open to all suggestions at this point. This guitar is a little dark sounding generally so brighter would be good to.
  2. YoGeorge
    YoGeorge Tele-Afflicted
    Michigan
    Any good clean PAF pickup should do it. I have a big Duncan '59 bucker in the neck of a tele with a Duncan Hot Tele in the bridge. Love the Duncan '59, which Fender uses in a lot of its own Custom Shop teles. Duncan Jazz would also be good, and I am guessing that Dimarzio makes some nice PAF buckers as well.
    I believe Duncans and Dimarzios have the same polarity so they should be in phase, but if you have 4-wire pickups it's not a big deal to flip one anyway.
    George
  3. tekbow
    tekbow Tele-Afflicted
    Dimarzio Twang King?
    it's what comes as standard on the kotzen teles and is an epic combo.
    Edit: whoops, bucker, never mind
  4. Matthias
    Matthias Friend of Leo's Gold Supporter
    They're 9k, right? Something around 7.5 - 8k for volume, I'd say. Stick to the lower end of that for a bit more clarity on the cleans. If your guitar is already a bit dark, consider going lower and sacrificing a bit of volume. A Tonerider Alnico II or (at just a little over $75) a Gibson 490r might be good places to start your search.
  5. Fred Rogers
    Fred Rogers Tele-Afflicted
    Long Island
    +1
  6. GhostofJohnToad
    Toledo, Ohio
    I thought about a twang king but wanted the look and quietness of the bucker. I have pick guards cut for both sizes so maybe I'll investigate the twang king as well. Have to fire up the YouTube demos.
  7. YoGeorge
    Michigan
    I'd go totally noiseless if you put the Chopper in the bridge. Just get a nice PAF thingie. My problem is that I like neck buckers just fine but have never found a bridge bucker that worked for my head and fingers... Always wanted to try a Chopper or something like that.
    George
  8. Andy B
    Andy B Friend of Leo's Silver Supporter
    Castle Rock, Colorado
    Duncan Vintage Firebird is my choice. Also have had good luck with 60's Gibson Mini Humbuckers
  9. YoGeorge
    Michigan
    Yeah, a minibucker is ALWAYS good on a tele as well. Maybe a Dimarzio version to ensure it's in phase. Probably a bit harder to find a pickguard for a mini, and note that Gibson minis are a bit smaller than Duncans (a Hot Rod 52 tele with a Lollar--Gibson sized) has a little space around it.
    George
