Nashville Deluxe series/parallel wiring with different brand pickups
Vdbroebr
Belgium
Howdy,
I bought a nashville deluxe power tele, but I want to change the stock TexMex pickups and change the wiring to fit my needs.
Because I often play higain and distortion, the pickups squeeled like a pig so they need to be changed with a set that is wax potted or noiseless.
The nashville deluxe tele needs to sound more like a tele (bridge + neck in parallel), but should also be able to kick like a mule (humbucker sound).
I prefer not to add extra switches or push-pulls, because I don't want to further complicate this guitar.
Wiring should be something like this (no switches!!!):
1. bridge
2. bridge + middle in series (humbucker mode)
3. bridge + neck in parallel (classic tele mode)
4. either middle alone or something out of phase, depending on what is possible (surplus mode)
5. neck
Pickups:
I really really like the Lollar set Special T bridge + vintage T neck.
The middle PU is somewhat of a problem.
I like the Seymour Duncan Hot Stack STK 2N, because it sounds different and hot.
Here are my questions:
- It seems there is no option to choose between a middle or neck pickup on the Seymour Duncan shop. Why is that?
- Does the Hot Stack middle pickup have the right polarity for the Lollar set (Bridge RWRP / Middle non-RWRP / Neck non-RWRP)?
- Is it possible to wire the lollar special in series with the SD Hot Stack? Or does the hot stack need to be split or whatever? I need to have a megalithic humbucker sound with this one!
- Is it an option to wire the middle and neck pickup out of phase or will the sound difference be negligible?
Thanx!!!
wabashslim
Sonorous Desert
LOL!
You're going to need a 5-way Superswitch at the least. The stock 5-way is just a 3-way with a couple extra detents. The 4-way does more than the 5-way!
The rest of your questions would best be asked on Duncan's site IMO.
