notmyusualuserid
Nice.
I gigged with a AC15 for years. It did everything I wanted it to well.
I am the same way, although that’s like saying I like chocolate ice cream better than vanilla.I know the Blue will be a much more authentic tone, but I always like ceramic speakers better than alnico for some reason. I know it is sacrilegious to say that…
Say wha-a-at? My friend has one and he's 81 and in OK shape for his age. He hauls it to gigs 3 times a week. I know they make lighter amps, but 48 lbs. is not that heavy, especially if you want the Vox sound. And Harbor Freight and other places have these little collapsing aluminum handcarts that are convenient for this.If you are between 20 and 40 and gigging ...fit as gym instructor...and can bench press 48lbs regularly then go for it....if you're between 20 and 70...unfit and can barely lift 48lbs but the amp is going to stay in one place in your bedroom for 20 odd years...go for it...if you're unfit and gigging every week pass on it cos it weighs the same as a small car and you'll end up in hospital !!
I struggled to get comfortable with my AC15C1 - probably something I missed trying to dial it in. Plus it was quite heavy by comparison to my Fenders. Purchased the AC10 just out of curiosity and it turned out to be that 60's sound that was in my head. Sound appreciation is subjective but I am subjectively biased towards mine.
81 !!!!!!! I tip my hat to him....that's one dedicated blokeSay wha-a-at? My friend has one and he's 81 and in OK shape for his age. He hauls it to gigs 3 times a week. I know they make lighter amps, but 48 lbs. is not that heavy, especially if you want the Vox sound. And Harbor Freight and other places have these little collapsing aluminum handcarts that are convenient for this.
View attachment 1049586 View attachment 1049587
Try top boost with treble all way down and bass at 11 o’clockHmm, I’m struggling to get comfortable with mine as well. Really has to be dialed in just so.
I’ve concluded I don’t much care for the top boost channel. And the normal channel is too dark for my new Revstar. I may need to explore the AC-15 with pedals though. Because I’m theory it has everything I need (reverb, tremolo, dirt) I haven’t spent much time putting overdrives in front of it.
Tried…. no joy. It’s ok. The normal channel is fine. I think I just need to put an overdrive in front of this and keep the channel volume a little lower.Try top boost with treble all way down and bass at 11 o’clock
Hey I hope you can dial it in. It is so well loved but my preference is the AC10. Good Luck.Hmm, I’m struggling to get comfortable with mine as well. Really has to be dialed in just so.
on mine, i use a morley aby pedal and dial in the two volumes to my liking. great sound. no need for any pedal.Hmm, I’m struggling to get comfortable with mine as well. Really has to be dialed in just so.
Google "AC15 Top Boost mod". Simple delete of one resistor, if I remember. Did it to the AC15 I had and liked it. Sold the amp just because I wanted a new flavor.Tried…. no joy. It’s ok. The normal channel is fine. I think I just need to put an overdrive in front of this and keep the channel volume a little lower.
Eh, I'm pretty sure I'm going to unload it first chance I get. I had been Vox-curious for a long time and figured buying a demo unit with the non-standard blue covering would be an easy out if it didn't pan out.Google "AC15 Top Boost mod". Simple delete of one resistor, if I remember. Did it to the AC15 I had and liked it. Sold the amp just because I wanted a new flavor.
I don't have that amp, but I've put knobs with set screws on those types of shafts, with teeth or whatever they're called, with no problems.I'm trying to find white or cream knobs for mine. Haven't been able to find push-on 6mm ones, only ones for solid shafts with a set screw.
