maches
I recently picked up a 70's Ampeg GT-10 solid state amp. I bought it real cheap on CL and didn't have a chance to test it out. I planned to stick in my garage so I could test pedals that I'm working on without bringing them inside. I wasn't too worried what it sounded like. When I got home and plugged it in it had a really loud hiss to it. Since I have some experience with amps I thought I try to fix the problem myself if it's not too extensive or expensive.
The amp came with a 2 prong cable which the original owner cut and extended with another 2 prong cable. When I opened the amp I noticed some of the electrolytic caps looked like they may have leaked. I ordered an 8ft. 3 prong cable and all the electrolytic caps to recap the amp. I'm pretty sure that the 2 prong cable isn't the culprit of the loud hiss (just safer), but I wasn't sure about the caps since they are 30+ years old..
From some of the reading I've done on upgrading from 2 prong to 3 prong cables an isolation transformer is recommended if one is not present. I'm pretty sure this amp doesn't have one. Would it be a big deal to go without one? Any other thoughts on the cause of the noise?
image removed
image removed
image removed
image removed
image removed
image removed
