Shannow985
Hello everybody,
I'm new here and hope somebody can help me.
I just acquired a Deluxe Reverb from 1974, an import version (France here) and wanted to swap the aftermarket power transformer to a more conventional one from TAD.
Everything looks straightforward except the input bias voltage. From what I understand the PT should feed 50v AC to the 470ohm resistor before the diode (blue/red lead). The PT that is currently installed doesn't have a 50v output and the 330v output was used instead (Y lead split with the main rectifier section PT output : 308v was measured).
In order to do this apparently a bigger resistor was installed to drop voltage 33k + 47k(<- where the 470ohms should be). So far so good.
Where I'm baffled is that I measured 257v AC where I should input the 50v (blue/red PT lead) and I have 197v AC before the Diode... After the diode I have -48.5v DC and -34.6v DC on bias pot which is correct, everything works fine ! A 22k has been put one the bias pot instead of the 10k as well I should mention.
Everything else on this PT is fine and should be straightforward to swap the new PT. The rest of the deluxe reverb is standard for it's era (A1172) apart that a SS rectifier was used instead of Tube but that's another story.
I fear that putting the new PT 50v where at the moment I have 197v will upset thing (putting the 470ohm back to specs + 10k on the bias pot).
I do have pictures of the reading + circuit but they're dark as it's night time here ATM. I can take them again tomorrow in daylight.
Many thanks in advance
Jonathan
Edit: Ok it's called bias tap what i'm dealing with.
Jonathan
