My version of the AC15
Discussion in 'Shock Brother's DIY Amps' started by voskarp, Nov 21, 2021.
Tags:
  1. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    I'm about to build an AC15, and this is the schematic I've come up with.
    My sources has mainly been the original 60's VOX AC15 and the later hand wired reissue.
    My version is closest to the HW one, but I have thrown in a AC30/6 normal-channel, a channel jumper switch, a high gain switch cascading the "normal"-channel into the EF86; and my modification of the "Brilliance" switch to a potentiometer (which I call the Bass Cut).
    The Top Boost channel is purposely made to be out of phase with the "normal"-channel, so that you can combine them to get a blackfaceish sound that the original AC30 with Top Boost could get.
    I am now working on a layout, incorporating the latest research into parts placement and grounding! ;)
    It will be in a combo cabinet with one 12" speaker; so I've done some research on how to keep the EF86 from getting too microphonic, and I've also got the Tung Sol reissue EF86 (which should be better than the Electro Harmonix I used in my AC4).
    I'm also not quite sure what speaker to use, the AlNiCo Blue is of course the best, but a bit too pricy in my opinion (if you not just have to get the right sound).
    The Celestion V-type and the G12H Anniversary are the ones that I've thought about to get reasonably close to a vintage sound. Any suggestions?
  2. kLyon
    kLyon Tele-Holic Platinum Supporter
    US
    My only suggestion: make it out of lighter wood than Vox does.
    (And then make me one:))
  3. 2L man
    2L man Tele-Holic
    Finland
    I would use a Star grounding when there are that many parallel pre amp stages.
    Blackbird 40 is very good sounding speaker when amp has max 20W. It is cheaper, lighter bit sweeter than Blue and sound close to Gold but without schrilling sounds Gold sometimes produce.
    I follow your build journey with high intrest because I have not built true AC yet. I had AC30 already 40 years ago and I miss its sound but not its weight and loudness :)
    voskarp likes this.
  4. 2L man
    2L man Tele-Holic
    Finland
    That third schematic has a "ground loop breaker circuit" drawn below power transformer.
    voskarp likes this.
  5. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    I think the newer cabinets are made of MDF, it is heavy...
  6. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    Speaker-wise I'm now thinking about the Celestion G12H 70th Anniversary Special Edition or Vintage 30 (at about half the price of an AlNiCo Blue). Any thoughts on that?
    I thought that the Blackbird really was a good sounding speaker, but better suited for a Fender style amp.
    The Weber ceramic Blue Dog is hard to come by here, and it's almost at €200, so two thirds to the price of an AlNiCo Blue... So if you've gone that distance, better go all the way.
  7. Dacious
    Dacious Doctor of Teleocity
    Godzone
    The G12H is a good choice. It's open and quite efficient. A bit smoother than a Greenback. I wouldnt go V30. Bit spikey for a treblish Topboost circuit. A Greenback actually works quite well.
    voskarp likes this.
  8. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    I find that the G12H Anniversary Special Edition frequency response curve (dark gray) is quite similar to the AlNiCo Blue (red). The V30 (white) is more different in the high mids and treble.
    LightningPhil likes this.
  9. 2L man
    2L man Tele-Holic
    Finland
    BB40 does B May kind sound at least as well as Blue and sound great with EL84 tubes. For vintage Fender sound I like Jensen Vintages more but BB is great with 6L6 amps too. There are four Blackbird 40 youtubes worth searching but to find one you need to use also word Toob and there it is against Tornado 100. I think BB40 has potential to become a classico and it could have been painted using sexier color and there Italians failed now :)
  10. Orpheum
    Orpheum TDPRI Member
    south of France
    I might as well get started in the making of a guitar, acoustic or electric, as the realization of an amp paralyzes me ...
  11. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    Went with the AlNiCo Blue anyway... I don't know if it sounds twice as good, and I'm quite sure I would have been satisfied with the G12H 70thA.S.E., but what the heck... The Blue sounds sooooo sweet!
    All parts are now ordered...
    Now back to get the layout finished! (Any day now...:rolleyes:)
    2L man likes this.
  12. andrewRneumann
    andrewRneumann Tele-Afflicted
    Cincinnati, OH, USA
    I think you will need a 100n (if blocking distortion is a problem, might have to be reduced) cap here between V4B grid and ground.
    voskarp likes this.
  13. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    I see now that it's in the HW schematic (R14), but it goes to the ch1 volume wiper.
    I thought it just had something to do with the "brilliance" switch thing, as it is not in the original schematic.
    What is the sign of blocking distortion (more than distortion in general)?
  14. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    OK, now I see it in the original schematic, but it goes to the wiper of the trem./vibrato channel.
    Looking at some Fender schematics I see its everywhere where there's a long tailed pair P. I.
  15. andrewRneumann
    Cincinnati, OH, USA
    I suppose you could couple the J3 valves to that grid via a coupling cap. That would be similar to how the originals mixed the two signals.
    But if you aren’t mixing two signals with the LTP, then the non-inverting side (right side) needs to have steady DC bias voltage on its grid. It should have 0 AC voltage—thus the need for a coupling cap to ground.
    voskarp likes this.
  16. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    It's in the Tweed Bassman and the Deluxe Reverb
  17. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    OK, that sounds right.
    Now I have read a bit about it, of course it's right! :)
    http://www.valvewizard.co.uk/acltp.html
  18. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    .1µF cap added from V4b grid to ground. Thanks for the help with that!
    Also added a 8,2Ohm 25W resistor from the speaker jack switch to ground.
    andrewRneumann likes this.
  19. David Barnett
    David Barnett Doctor of Teleocity Ad Free Member
    Can I suggest that if you put the EF86 and the Normal channel on one side of the phase splitter, and the Top Boost channel on the other, you'll be able to combine any of them without cancellation.
  20. 2L man
    2L man Tele-Holic
    Finland
    Quite often on Vox type amps both phase inverter anode resistors are 100k but on majotity guitar amps other is 82k (R27 on yours) Obviously using different values power tubes drive signals come better balanced. Can anyone tell if slight unbalance is substantial for Voxy sound?
