My strat tone is hosed after some maintenance
Discussion in 'Stratocaster Discussion Forum' started by GeorgeG, Feb 17, 2020.
  1. GeorgeG
    GeorgeG TDPRI Member
    I have had this MIJ Fender Strat for over 30 years. I recently replaced a scratchy 5 way switch, re-installed the original single coil bridge pick up (I had a mini humbucker in the bridge position for about a year) and put new strings on the guitar. The result is really thin tone and lower output with all pick ups. I was mostly playing the middle pick up lately. I certainly understand new strings sounding brighter but something else is going on here. Its so thin and tinny that I can barely stand playing it. I just took the pick guard back out and double checked the wiring and it all looks good.
    Does anyone have any suggestions on something that I can check to see what changed/went wrong.
    Thanks,
    George
  2. TeleTucson
    TeleTucson Tele-Afflicted
    Tucson, AZ
    If it seems thin and low output with all pickups, it could easily be a problem with the phase of the pickups - i.e., that you've switched the leads of original pickup when you rewired it.
    Or, you just got used to the humbucker and the single-coil bridge sounds thin now.
    Zepfan, bgmacaw and fenderchamp like this.
  3. 24 track
    kamloops bc
    I was never fond of stock strat singles all of them sounded week and wimpy , I built several pickguiards (6 of them) and found Lace alumatone pickups I love then ,I also have lace sensor rainbow pack hot gols 13K in the bridge, silver in the mid and dark blue in the neck . these also sound great and are dead quiet .
    one thing you could try is to take out all of the pick guard screws and see if the sound changes, if it comes to life put the screws back one at a time and check it after each screw , the reason for this is there may be a contact touching ground as you tighten the guard down causing your issues.
  4. max_twang
    max_twang Tele-Afflicted
    New York
    I think Tele Tucson is onto the problem.
    Get yourself a standard wiring diagram and compare it to your guitar. If there are any differences, fix 'em.
    Wildcard_35 and hemingway like this.
  5. Cysquatch
    Cysquatch Tele-Holic
    Grovetown, GA
    If you upload a quick snippet of audio from the pickups we could tell you right away if it's a phase issue or just thin pickups. My money is with @TeleTucson, though.
  6. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    that new switch... is a printed circuit board type? I've seen those suck tone big time
  7. Don Miller
    Don Miller Tele-Afflicted
    Anchorage, Alaska
    Any phasing issues from the reinstalled bridge pickup would appear in the 2nd position (Bridge and middle pickups)….the output would be ok for the bridge pickup alone, or for the middle and neck pickups, either alone or together...sounds like you maybe getting the diminished signal with all the pickups....positions 1 thru 5?
    You mentioned the bridge pickup was a fender....are the other two Fender as well? Fender pickups, with the bridge pickup wired correctly, are out of phase with many other aftermarket pickups....Duncan, DiMarzio, No-name, etc....If the output in the 2nd position is markedly different than the others, try swapping the hot and ground leads on the bridge pickup and see if that improves things....
    Did you change any of the pots or tone cap when you put the humbucker in or took it out?
    If its not the phasing, could the pickup have been damaged while it was out of the guitar?
    Check the switch...as Dogmeat suggested, there can be tone sucking components...or...I've messed up a switch during the install....it happens...or its not unheard of to get a bad one....so maybe spray the old one with contact cleaner, put it back in, and see if that improves things....
    Sometimes you need to take a magnifying glass and check everything...all it takes is one errant strand of wire...or bit of solder in the wrong place...and you have a dilemma...
    good luck and keep us posted....
    Wildcard_35 and dswo like this.
  8. hopdybob
    hopdybob Tele-Afflicted
    netherlands
    sometimes when tweaking on wiring, wires turn and just behind the soldering they twist en copper wires break so you can have a connection with 1 ore 2 little wires without knowing.
    what you could try is measure the ohm readings at some places.
    direct hot and ground, and move on to the jack.
    but because you removed and placed en pickup the ground connection on the volume pot probably is heated up twice.
    getting the ground loose from the old pup en again for the new on.
    this could damage the pot.
    (that is why i alway use a piece of used desolder braid, solder that onto the pot and make sure it has enough length to connect other ground wires without heating the pot surface again.)
  9. GeorgeG
    Some good ideas, I'll report back.
    George
  10. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    If that bridge pickup is volume only like the usual old layout, swich the second tone pot wire from the middle pickup terminal on the switch and put it on the bridge pickup. That will fatten up the bridge pickup a bit and makes the middle pickup less dark in the neck/middle position.
    Also put a series/parallel mini-toggle on the middle pickup for some extra sizzle in the #2 & #4 positions.
    If the Strat Bridge pickup still doesn't do it for you and you want a good single coil pickup, try a Deneb-Tone Neodymium pickup or a Cavalier Fat Lion Tele bridge pickup instead. P90 could be a good choice too.
  11. schmee
    You probably have a wire touching somewhere it shouldn't or something done wrong. Sometimes the wires are fine until you screw down the pickguard and then one is forced onto a por or switch lightly grounding it.
    kookaburra and awasson like this.
