My son has a scratchy Vox wah pedal!
Discussion in 'Pedal/Effects Owners Clubs' started by Billy3, Feb 22, 2021.
  1. Billy3
    Billy3 Tele-Meister
    Charleston,Sc
    Hi there! So my son bought a brand new Vox V845 wah pedal a year ago. When pressing the toe end down it is very scrathy. Should I take it apart and use deoxit or what else does anyone think I should do? Is it a potentiometer issue? Just looking for some advice before I get into it. Thanks! Keep on pickin!!! P.s. If I need to use deoxit, what type should I buy for pots,pedals and movable electronic guitar parts?
    boredguy6060 likes this.
  2. Fretting out
    Land of Mary
    I think I’d spray it with some contact cleaner (the pot that is) and maybe even re-grease it
    If you/he has animals the lithium grease in those wahs attract hair and such
    rze99 likes this.
  3. Buzzgrowl
    Buzzgrowl Tele-Meister
    Switzerland
    I did that a few times, it was a temporary fix. Eventually gifted it to a friend who put in a fancy sealed pot.
    I bought a Morley for myself.
  4. kennl
    kennl Tele-Afflicted
    Moon Township, PA
    wah pot should last longer than a year
    DeOxit should fix it
    while it's open you can adjust the rack and gear for preferred sweep
    grease the rack
    tighten the input and output jacks and DeOxit them as well
    DeOxit the switch and adjust its height so it switches without excess pressure, and does not switch unintentionally
    adjust tension band screw
    should then be good for 1000 choruses of "Papa Was a Rollin' Stone"
    Fretting out likes this.
  5. Billy3
    Billy3 Tele-Meister
    Charleston,Sc
    Is contact cleaner the same as deoxit?
  6. Ziggy587
    Ziggy587 Tele-Meister
    NY
    I actually just recently posted a thread about a used Vox wah that I picked up. I've adjusted the rack and pinion on several Cry Baby wahs and it was no big deal. But the Vox that I just got, it was my experience that there is no margin to adjust the rack. If it isn't on the exact right tooth, then the wah wouldn't function properly. The Cry Baby has a few teeth in either direction where it'll still function as intended, but the Vox does not. At least my Vox didn't. It was very annoying because I thought there was something wrong with it, since I got it used. Adjusting the rack was the first thing I did, and I was use to having some room for play like my Cry Baby wahs, so when it still didn't work after adjusting it I was assuming there was something wrong. I posted a thread here asking for help, then tried adjusting the rack again. This time I spend a little more time fiddling with it, listening to the sweep as I was adjusting it, and was finally able to get it to work correctly.
  7. Alex_C
    Alex_C Tele-Meister
    Deoxit is a contact cleaner. Deoxit has an oily substance that conditions the pot's carbon track vs. the contact cleaners that dry up. Deoxit seems to make my pots stay clean for a longer period.
    Billy3 likes this.
  8. drf64
    drf64 Poster Extraordinaire
    Ada, MI
    Ike Turner would never hire him.
    MickM likes this.
