My Missing Images
Discussion in 'Shock Brother's DIY Amps' started by robrob, Jan 2, 2021.
  1. backporchmusic
    backporchmusic Friend of Leo's
    Hmmmm...it may be something between your server and TDPRI then?
  2. robrob
    United States
    A 4000x wide layout linked to from The Gear Page:
  3. robrob
    United States
    EDIT: NOT SOLVED: tdpri is blocking all my website images, even small ones.
    backporchmusic likes this.
  4. robrob
    United States
    After examining the image I found that is was actually reduced by Facebook. I did the same test using The Gear Page and the large image is being blocked. ^See above a few posts.
  5. robrob
    United States
    I have not been able to get through to a tdpri admin or webmaster. Maybe if several people click on the "Contact Us" link at the bottom of this page tdpri will respond.
  6. SRHmusic
    SRHmusic Tele-Holic Silver Supporter
    North Carolina, USA
    We could "Report" one of the posts by @robrob to ensure ab admin sees it, but I don't want to misuse the reporting system
    Maybe give the admins a day or two to get back to your contact request?
    robrob likes this.
  7. robrob
    United States
    The real pisser is that the change was retroactive.
    GoldDeluxe5E3 and Drew617 like this.
  8. RollingBender
    RollingBender Tele-Afflicted Vendor Member
    SW Minnesota
    @robrob. I sent you a PM with contact info for the owner here. I had an issue a couple weeks ago with my vendor status and he got right to the bottom of it.
    ...plus, his name is Rob so he has to be a good guy!
    Nickfl and robrob like this.
  9. robrob
    United States
    Thanks RB, an email has been sent to the tdpri owner.
  10. Phrygian77
    Crawfordville, FL
    Doesn't make a lot of sense because that shouldn't effect their server or bandwidth with the images being hosted third party.
    GoldDeluxe5E3 likes this.
  11. cometazzi
    cometazzi Tele-Holic Silver Supporter
    Wisconsin, Das Land von Käse und Bier
    That's what I was about to say.
  12. glenlivet
    glenlivet Tele-Afflicted
    Marco.......Polo......
  13. glenlivet
    It showed up (the image ) in the preview windows....but not after I hit post
  14. robrob
    United States
    "Doesn't make a lot of sense because that shouldn't effect their server or bandwidth with the images being hosted third party."
    tdpri has always uploaded images for their hosting whether you copy and paste into a post or use the "image icon". This causes problems for me because when I edit a layout tdpri won't update the image.
    The size limit also seems to be related to image complexity. Someone posted a very simple 4000x3000 black and white image without problem so I believe tdpri compresses images when they upload them and my complex layouts don't compress that well so they get blocked for being "too large".
  15. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    The server proxies the images so every bit would go thru their side both down and up. If you look at the URL to the dead image link above you'll see it's requesting the image via the TDPRI site. So the proxy is failing to serve to these larger images.
    Phrygian77 and robrob like this.
  16. glenlivet
  17. glenlivet
    this time I removed the https and just accessed the link via http
    looks like maybe the proxy might not like the https links.
  18. glenlivet
    "http://robrobinette.com/images/Guit...104_Master_Volume_Micro_EF80_Layout_small.png"
    "https://robrobinette.com/images/Gui...104_Master_Volume_Micro_EF80_Layout_small.png"
  19. glenlivet
    hummmm .... OK...... https "links" work.... but maybe not embedded https links to images....
  20. robrob
    United States
    Oh crap, there goes the "size and complexity" theory. ^image is a small black-and-white EF80 pinout diagram from my website. When I edit this post I see the image.
