My Les Paul Jr DC
Discussion in 'Tele Home Depot' started by dietrichluthier, Sep 15, 2010.
  1. dietrichluthier
    dietrichluthier Tele-Meister
    Argentina
    Hello Friends
    Excuse my English is not good:(
    will try to make a vintage Junior with some specifications (thanks to Gil)
    level I've used this renovated, qeu information gathering with the time I
    well let the pictures
    Templates
    much dust
    sorry
    I have no photos of the staff of mast
  2. RodeoTex
    RodeoTex Doctor of Teleocity
    Nueces Strip
    Very cool Dietrich. I've always loved those double cuts.
  3. dietrichluthier
    Argentina
    worked wood
    South American Mahogany
    cut mahogany, for this is using the router table
    cavities are pickups
    perfect, very well
    cavity control
    cavity drilled wick 25.4mm
    perfect, very well
    too late, I'm going to rest
    see you soon
  4. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Athens, GA
    Are you making the angle for the neck pocket on the body or on the neck?
    Looks like you added a stop tail to your pattern too, is that right? I kinda like the wraparound, having the strings in contact with that much metal gives that brassy tone and sustain that really makes the "Junior" sound IMO.
    I love the doublecut shape too, very Johnny Thunders.
  5. titoc
    titoc TDPRI Member
    New Mexico
    Muy bien amigo! Bueno suerte con su projecta.
  6. dietrichluthier
    Argentina
    There is good progress
    Cavity is drilled jack, 25.4mm
    Completed, well
    The mahogany neck is prepared, is left to 57 mm wide
    This is the template I use to cut the 17 degrees of headstcok, cut with the closing table
    perfect cut and tidy
    this is all for today
  7. Mojotron
    Mojotron Poster Extraordinaire
    Seattle
    Looks awesome so far.
    Anyone know of a template plan for the LPDC?
  8. dietrichluthier
    Argentina
    Hello friend
    Thanks for the comment
    If you want it I can spend my shots, approach the 57 original
  9. hockeygoon
    hockeygoon Tele-Holic
    Norwich CT
  10. Mojotron
    Seattle
  11. dietrichluthier
    Argentina
    More progress
    a high-tech device! :naughty:
    is a template on each side of the handle 17 degrees to correct the tuning is so perfect at 17 degrees
    Well let the photos I think it explains itself
    Very well be subject to the templates neck
    To rectify the router and used a cutting-edge strawberry
    Completed, it is so
    Regards:D
  12. dietrichluthier
    Argentina
    more progress
    We must make the hole for the truss rod nut "nut" (as some call it)
    For that use a perforated wooden nitrous cut to 17 º and a lock of 17mm 4-pin
    Tested on a piece of pine to not ruin the work
    While I agree, maybe a little long, but well ....
    Now to do the shovel Jr
    Another shot
    Here you can see I spend a few mm
    Arranged and Perfect!
    Well that's it for another day today we continue with the tensor
    Lucky:p
  13. Thunders1988
    Thunders1988 Tele-Meister
    Belgium
    Great! This looks like a place to gather a lot of information for my next build (next to ScatterLee's).
    Good job, sir. Johnny Thunders would be proud! :D
    PS: please tell me you're doing it TV Yellow?
  14. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    Looking great dietrichluthier.
    Why not get a longer bit for the mortise... extending those long bits out of the collet in order to get a deeper cut is very dangerous. Don't ask me how I know...
  15. dietrichluthier
    Argentina
    Thanks friend
    ScatterLee's is very good builder, his post has a lot of information
    Sorry, but TV would not be a yellow, red cherry will
    like this
    Gil is an honor you're here, I've learned a lot about you
    I know what you mean, but is the router bit safer than I could buy
    We have a job that is dangerous
    Once when I was 21 years, I remove it with a fingernail bandsaw, really hurt
  16. dietrichluthier
    Argentina
    commencing with the straight channel
    It's my first time going to this type of channel ahcer
    Can someone explain how this type of compression rod:rolleyes:
    well here the photos
    I'm slowly using a router bit 3 / 16
    good, very good
    I'm using stainless steel 3 / 16, failure to make the nut thread
    Greetings:D
  17. dietrichluthier
    Argentina
    I've been doing color tests with filler paste
    is more red in the picture is not well appreciated
    I have tried in excess of mahogany, I want your opinion on the correct pitch
    Test 1
    test 2
    Test 3
    which of the three is similar to the original?:hmm:
    Thanks for your time
  18. dietrichluthier
    Argentina
    it was time to start making the trus rod, as I said earlier I'm using stainless steel 3 / 16
    I will show that if I do not like nuts Brass / bronze, which are available in stewmac the coins sold, but I have nothing more to ask so that I do, and ready
    Well you need
    Hexagonal brass rod 5 / 32
    Macho y terraja 10-32 unf
    and a beast like this
    aqui se puede ver como se esta haciendo la tuerca el ángulo del bisel es de 17º
    Nut good list here, sorry no pictures of the moment to the thread where
    Level is tested to see if this well,
    Now tested with an iron rod that had previously drawn, the thread is perfect, fits very well in the hole
    Well that's it for today
    Greetings
  19. OpenG Capo4
    Athens, GA
    Watching this one closely. ;)
  20. dietrichluthier
    Argentina
    It does bolt truss rods, drilled and welded and is in one piece
    10-32 thread
    It covers the scroll bar of steel with a piece of hard maple, glued with hot glue (hide glue)
    after a few days the glue dries remove the maple exedentent
    continue with the fingerboard (rosewood), very bright indeed:)
    Cuts are made will go where the dishes, and begin to sand the radio (12)
    Much sand
    To do this use a guide to which the cue does not run, it looks like a perfectly flat table of the planer
    They are made with chalk lines to see if it goes well
    lack a bit in the end, it is hard to see
    Once over the radio, holes are made of pearl items, they must be 7mm but I failed, so these are 6mm
    Place stick and re-sanding
    I am very well!
    until next time:D
