My first set neck with long tennon
Discussion in 'Tele Home Depot' started by Clintstone, Aug 18, 2019.
  1. DrASATele
    North of Boston
    Not sure what you mean? . . the explorer is on my table saw, the purple heart is on a counter top
  2. Clintstone
    Clintstone Tele-Meister
    Brandon Manitoba
    Getting my fretboard taper nice and straight.
    Irondog and Jim_in_PA like this.
  3. Clintstone
    Brandon Manitoba
    guitarbuilder and Jake Nelson like this.
  4. Clintstone
    Brandon Manitoba
    Jim_in_PA likes this.
  5. Clintstone
    Brandon Manitoba
    You know you have a good neck joint when you can hang it on a guitar stand and it's not glued yet.
    ejphotos, Macrogats, RodeoTex and 2 others like this.
  6. Clintstone
    Brandon Manitoba
    Just making sure the hardware lines up before starting the grain filling. I just need my pickguard material to show up. 20191003_171404.jpg
    RiversQC likes this.
  7. Clintstone
    Brandon Manitoba
    If you dont have one of these 18" radius sanding beams you need one. This was my first fretboard I radiused with a real sanding beam and man does it ever make the job easy, definitely worth the money. 20191004_204839.jpg
  8. Clintstone
    Brandon Manitoba
    Rollin some fretwire on my homebrew fret roller
  9. LuckyJinx
    LuckyJinx TDPRI Member
    Portsmouth, Shire of Hamp
    If you smear those bits with glue, doesn't it scrape off all the glue when you slide it in for the glue up and leave the joint dry? I'd worry there would not be enough glue left with a joint that tight.
  10. Clintstone
    Brandon Manitoba
    Most of what I have read leads me to believe a set neck should have a tight neck joint, so I guess I'll find out. Got my frets pressed in today.
    RickyRicardo and RiversQC like this.
  11. devrock
    devrock TDPRI Member
    New England
    Incorrect. Even with a super tight fit, there’s still a thin layer of glue to keep a strong grip.
  12. guitarbuilder
    guitarbuilder Telefied Silver Supporter
  13. Clintstone
    Brandon Manitoba
    Getting some strings on it to line up the bridge.
  14. Clintstone
    Brandon Manitoba
    Since this is for my buddy who is the biggest Kiss fan I know, I had to go with a single humbucker with a mirrored pickguard. 20191026_140300.jpg
    Captain Nutslot likes this.
  15. Clintstone
    Brandon Manitoba
    Done, this one came together pretty quickly, hence the lack of progress pics. But the neck feels good and it sounds super heavy. It even balances well and doesn't really neck dive. 20191026_154016.jpg
    Captain Nutslot and Jim_in_PA like this.
