Freeman Keller
This should probably be a new thread, but if you need any help I have had mine apart and back together a couple of times. As you probably know there are four flat head wood screws under marker dots on the fretboard extension that hold the neck onto the body plus one screw on the neck stick inside. Take those out and the neck falls off which would make it much easier to work on.Thanks, no binding anywhere on mine to contend with. I bought a pre sloted 25" maple board from stew Mac that I'm going to dye with India ink like the original. Should I dye it and install the dots before frets? Seems like I should.
Mine is in pieces but it is this exact model.
