JayneV
Totally agree with you Jim. I learned something new today regarding short belt drives as used in CNCs to transfer motion from the motor to a screw. The tooth profile is not as important as having correct tension and pulleys that are not too small. The idea is to have enough tension in the belt so that the leading edge of the first 4 or 5 teeth on the belt are positively engaged with the pulley teeth, then as the belt wraps around the back of the pulley, those teeth don’t really do much, then continuing around the pulley to the other side, the trailing edge of the last 4 or 5 teeth of the belt are engaged with the pulley teeth. That’s probably not a very good explanation, but if done correctly, it doesn’t matter which direction the belt rotates, there are always teeth positively engaged with the pulley with basically zero backlash. This also means pulleys with around 25 teeth are needed. Any perceived backlash then comes from the belt stretching under load which is minimal for a very short belt. Anyway, that is how it was explained to me which seems to make sense.
I got the quotes back today from the emails I sent out. One was around $150 and the other about $240 for three belts and six pulleys. I think the $150 quote was for the wrong parts so I sent them another email to confirm. The price is a little expensive but not unexpected from local suppliers. Tonight I sent a quote request to Powge at AliExpress. If they come back with a good price I will just order from them. It’s not like I have an urgent need for those parts, Carlos is still a long way for needing any drive system components.
Out of interest, I have heard that it is possible to compensate for backlash through the controller software. Thinking about the mathematics involved to accomplish this hurts my brain.
Has anybody had any experience with compensating for drive system backlash through the software? That sounds like a handy feature to have to fine tune the machine.
Jayne
Jayne
