MY CHAMP!!
Discussion in 'Shock Brother's DIY Amps' started by chazo64, Oct 24, 2021.
  1. chazo64
    chazo64 Tele-Meister
    Chipley ,Florida 32428
    About a mounth ago I bought a 5f1 from Boot hill, went like butter! I built the first box for it and really didnt like how i built it , but the final result sounds great I have some tweed to cover and some grill cloth coming. Any way i cant say enough about how much I love this little amp. SO....I am gonna build one for my son .I am building a new cabinet in my LOL shop/[email protected]##@!! My cabinet shop which was in Panama city blew away in the Hurricain 3 years ago as did my own garage /shop at my house so Here I am with my portable table saw and a sander and some glue .....Making a champ cab .I use a lap tenion to build this box ..I know what about a finger joint...short answer ...I dont want to! Long explaination..,Sorry I am about to soap box a bit..after 40 years in the woodworking trade I can say the dove tail and or the finger joint in PINE are not good construction..Pine is soft the smaller you make a piece of pine , it breaks .The handle is on top of the box, you lift up...the joint has no upward strength. Corner to corner as well, The lap tenion has massive stegnth to hold the box from pulling apart does it look as nice as a machined dovetail or fj in hardwood no way . but this is a champ! 20211024_125527.jpg 20211024_123342.jpg 20211024_123324.jpg My new shop 20211024_123314.jpg
  2. fendrguitplayr
    fendrguitplayr Doctor of Teleocity Silver Supporter
    New England
    Looks great!
    chazo64 likes this.
  3. Greggorios
    Greggorios Friend of Leo's Gold Supporter
    NY
    Nice effort. Great little amp deserving of a great cab!
    chazo64 likes this.
  4. El Tele Lobo
    El Tele Lobo Poster Extraordinaire Silver Supporter
    I’m interested in reading more about these 3 different joint types. Can you explain the differences for those of us who don’t have a woodworking background? Or post a graphic or link that does?
    chazo64 likes this.
  5. NTC
    NTC Tele-Holic
    Minor point - the speaker is typically mounted from the rear - inside the cabinet. It doesn't look like there is room for a grill cloth frame with it front mounted either.
    I wish I could build my own cab...
    Nickfl, Timbresmith1 and chazo64 like this.
  6. Timbresmith1
    Timbresmith1 Tele-Afflicted
    Central TX
    The box/finger-joint uses massive surface area for glue to do what it does. Incredible strength
    against racking forces.
    I do understand not wanting to do finger joints on a portable table-saw tho.
    jsnwhite619 and chazo64 like this.
  7. chazo64
    20211024_131215.jpg 20211024_130936.jpg some of the improvements over my first cab. .#1 13 3/4 wide 12" high and only 7 at the bottom and 6 1/2 on top for depth...I didnt like it everything fit but just didnt like it so cab #213 3/4" wide 12 3/4 " high and 8" bottom and 7" top depth this one of course is a glue only case no staples or nails the first one I was like...build box PLAY AMP NOW!! so I used some pins. Man I love the sound of this amp i have a gold lion 12ax7 in there with tung sols. with my p-90s it is absolutely amazing!! All my pedals just became paper wieghts!!$$##$#!
    Greggorios, robrob and El Tele Lobo like this.
  8. chazo64
    its temp. just wanted to fire up my amp the speaker panal is just a mock up its 3/32" too thin..
    NTC likes this.
  9. chazo64
    I am not literate enough to explain it but there is a lot of imfo on wood working out there.
  10. chazo64
    That whole first box is wrong ,not deep enough etc ....
  11. chazo64
    exactly I just didnt want to do the finger joint with no dado blade and I didnt want make a router table outside Here in florida it can dump gallons of H2O on you in a minute LOL..My other shop blew away to OZ or mabey Georgia
    El Tele Lobo and Timbresmith1 like this.
  12. m0b1liz3
    m0b1liz3 TDPRI Member
    I did box joints with pine and a dado blade. Pine is pretty soft and it is easy to get lots of tear out with the dado blades. Router set up with a jig might be the easiest. I actually considered taking a stab at box joints with just hand tools. Maybe just a coping saw and chisel + rasps/files would work.
    chazo64 likes this.
  13. mjcyates
    mjcyates Tele-Holic Ad Free Member
    Louisville, KY
    syscokid, Gimble and chazo64 like this.
  14. chazo64
    Backing your work piece with another piece of dunage will prevent tear out but thanks
  15. m0b1liz3
    Yeah, I should have spent a bit more time researching. Had taught myself how to use it. Was my stepdad's saw and he had passed away. Saw is gone now so next time around I will have to figure out a different way.
  16. chazo64
    A box joint shouldnt be to hard to do by hand with a back saw and a coping saw
