So I think I was successful on my first circuit mod I did myself. I wanted to add a tremolo to my stock Blackvibe Micro EF80 build. I use the tremolo circuit on the GA-19RVT as a starting point, since it is also a cathode biased amp. I pull the B+ for the plate on the tremolo circuit from B+4, but add an additional 100 ohm 1 watt resistor there to drop the voltage to 240 volts (as specified in the GA-19RVT) before it hits the Tremolo Plate Load resistor. Other change is I add a 1M resistor to the output of the tremolo where it connects to the level/depth pot to reduce the voltage being fed back into the power tube grids. Before adding the resistor I was measuring close to 50 volts peak to peak out of the tremolo circuit on my oscilloscope. The 1M resistor drops it to about 19 volts peak to peak, which still seems high to me, but everything works.
I've built and tested this and it works and sounds pretty good to me. Any problems or concerns or suggested revisions from people who are more knowledgeable.
Thanks!
Thanks!
