mountainhick
White looks heckofalot better.
Yeah. I was trying to match something like these. I think I got pretty close for everything else but will just settle for plain white. It'll still be good.White looks heckofalot better.
I've been playing around with different sizes of logos and also trying to see if I could make some that are gold. But, I think they are turning out way too splotchy and so I am probably just gonna go with plain white. Ideally if I could figure out how to taper/bevel the edges in the STL 3D artwork I would just have it print that way and with a small flat spot on the top I could paint that gold. But, I have seen pictures of Marshall amps where the cab has the gold piping and it still uses white lettering for the logo. They seem to look pretty good still.
View attachment 993834 View attachment 993835 View attachment 993836 View attachment 993837 View attachment 993838 View attachment 993839
Thanks man. These have been fun to work on. I'm wondering now what do I do?As with your other thread (Micro Bassman) your work on this TMB is exemplary.
I did actually build a new cab for my micro last week just not had time to write a post haha.
Ah, that could work. Definitely worth a shot. Maybe even only 0.5mm raised would be enough. At some point I'm going to try to figure out how to actually print a full on taper so it's skinnier at the face of the font and I can just paint that gold and it may look closer to the originals. For now, the white doesn't look too bad. Hehe.For your logo and gold lettering work, could you print the logos with the top face offset inwards by 1mm around the perimeter and offset above the top surface by the same. I'd then use a foam roller to just hit the top surface in gold. Foam rollers give a better finish as well, I use them for clear coats on furniture.
The 1mm offset should hopefully keep the gold nice and clear.
Other option would be to pad print it (I would expect this is how Marshall do it on the Reissues)
For you logo and gold work, could you print the logos with the top face offset inwards by 1mm around the perimeter and offset above the top surface by the same. I'd then use a foam roller to just hit the top surface.
Again, absolutely killer work.
Thanks man. These have been fun to work on. I'm wondering now what do I do?Of course, I need to learn how to play better. There are still a couple of mods I want to try out with the TMB ... and I have a thermistor arriving tomorrow to prevent the current inrush issue at mains power up. I'd love to see your micro when you're ready to show it.
Thanks. Of course ... that's actually how my Bassman Micro project started. I ran out of tolex for finishing my speaker cabs and realized I had to order more ... and there was plenty leftover to build another small amp head. Haha. What's crazy is that the micro amp easily cost me more than the Mojotone 18w TMB kit. I guess I could have bought cheaper components, but figured I would just make it really good (including the custom faceplates).They look amazing, haha that's always the problem when a project finishes, what next? And I have all these parts left?![]()
Excellent looking build so far! Interesting you also saw that there's less hum with the OT slightly tilted. When I installed it, I didn't bother to actually implement the tilt and it's actually super quiet. I mean, I could probably get it more quiet, but it's performing really well.I'll keep an eye out for any new project you start, your threads have lit a fire under my arse to try and get on with mine again.
My thread is here, ashamedly it's been going on for over 2 years now but having a 2 year old means most of my free time is taken up at the moment.
https://www.tdpri.com/threads/2nd-build-robs-jtm45-micro.1027897/
Not sure. I'll have to ask my friend who printed it for me. I designed the artwork with vector art in Photoshop, exported it to an .ai file so I could open it in Inkscape to convert it to an SVG that I then opened in tinkercad.com to make the .stl file.What CAD program do you run your printer from?
I couldn't find anything in tinkercad that would let me add draft. I imagine some pay-for CAD software could do that, like you suggest. I didn't know what feature to search for, so thank you for mentioning that it's called, "draft."If you can add draft to the part in CAD this will work (I am a product designer/product development manager and we use Solidworks at work) Draft is critical in manufacturing a plastic injection moulded part to allow the part to be extracted from tooling. This is obviously not a requirement for 3D printing but if you added a few degrees draft to your part before printing this will mean the lower section of the logo will naturally be wider than the top and will give the look of the gold being "framed" by the white. Just be sure the draft direction is correct, I'd say 2 degrees should give enough draft.
Anyone know of a good option there? I guess the other option could be to use a on/off switch in combination with a non-switching potentiometer. Or even an On-Off-On switch with two fixed resistors for a couple of different values.
Edit: Or…I just plug in the external attenuator. Ok, that’s much easier and probably a better sound. Just sometimes a pain.![]()
I came across this video explaining a type 3 post phase inverter master volume which, as far as I understands it, can lessen the MV by phase cancellation. I’ve got a handful of board-mounting potentiometers and tested it this morning to see what kind of affect it’d have and how it’d sound.
View attachment 995261 View attachment 995262
I started with a 100K potentiometer and I could barely turn the knob before it seemed at full blast. Eventually I worked down to a 5K pot and at the 5K setting the amp isn’t putting out full volume, but the range I get out of it is definitely home/bedroom worthy.
It seems like if I could find a 5K switching pot, that might be the best option. That way, I could mount it on the back panel (plenty of room back there) and switch it off for original stock capability and with it on the TMB’s MV and the normal channel’s volume knobs are much more usable at home.
That’s cool. I guess the one benefit of using an attenuator is that you can overdrive the power tubes. Both ways are probably good. I mean the whole point is just to not have ear-bleeding volumes and enjoy playing.I really don't miss the regular MV. I only have post PI volume and see no reason for switching to a regular one.
Is the attenuator that good? I feel that using the PPIMV lets the amp breathe more. An attenuator compresses more and diminishes some harmonics. To me an attenuated amp has the same feeling as a modeller. Sounds great but I like the PPIMV more. Maybe I'm fooling myself but if I am I'm ok with that.
I just used the 1M pot that was in the Madamp and the 1M from Rob's design. I can get a dirty tone at just above TV levels. I watch youtube lessons and play along.
Yeah, admittedly this is the part I don’t quite understand. Robinette reports that the type 3 works really well on his 5F6A amp, but maybe because it leans more to the clean territory vs. the 18w? He says to use a 1/2W pot and describes it in his 5F6A and 5E3 notes.I preach a dual gang pot for PPIMV if you have the space.
At 5K, I would start to worry about the power rating of the pot. If it is a 0.5W pot, then the rated rms voltage across 5K is 50VAC. Not out of the realm of possibility for a long tailed pair if on a relatively high voltage supply. Plus you want some buffer in there... 2x to 3x more power capacity then regularly demanded e.g.
Do you mean the Lar/Mar type? Maybe I haven't found the right version buta lot of the options for ppi-mv's are for fixed bias. If I'm not mistaken the 18w and the Bassman-micro are Cathode bias. How would you implement a post phase inverter MV on those?I preach a dual gang pot for PPIMV if you have the space.
On Rob's Trainwreck pages, search for the Type 2 master volume. Yes, according to Rob, a version of it is called the Lar Mar version.
I assume then that if I were to add this I would use a 500k/500k potentiometer with a 7.87MOhm resistor across the terminals of each of the pot lugs to effectively have 470K with the potentiometer turned all the way up.
Normally grid stopper resistors go to ground in series with the grid leak resistors. But these don’t. Is this just a different way of using grid stoppers? Would I leave those in place and connect the PPIMV wires at same turrets where the green wires (green wires would be removed) connect?
