MXR Iso-Brick?
Discussion in 'The Stomp Box' started by nathanteal, Apr 12, 2015.
  1. nathanteal
    nathanteal Tele-Holic
    Rochester, NY
    Good? Bad? Y/N?
  2. FenderLover
    Minnesota
    That's a very good question.
    1) They are not specific at all what Fully Isolated means. Their web site has very little information.
    2) I fail to see the advantage in supplying two outputs at 9V@100mA, 2x9V @300mA, 2x9V@450mA, and so forth when the simplest regulator chips that they buy for $0.20 each will do 9V@1000mA each.
    If anyone has one, I'd appreciate a gut shot to see if the transformer has 10 separate outputs, because if it doesn't, it's not Fully Isolated.
    That doesn't mean it won't work for you though.
  3. RyanJH
    RyanJH Tele-Meister
    Just because the regulators can put out 1000ma, doesn't meant the secondaries can supply that much to each regulator.
    -Ryan
  4. Middleman
    Middleman Friend of Leo's
    MV, CA
    I've got one for a small pedal board and it does just as good as my Voodoo power supply on my larger pedal board.
    I'm running a min fuzz face, EP Booster, Tube screamer mini, Keeley compressor 2 knob, TC Flashback Delay and a Wampler Tape Echo. No problems.
  5. nathanteal
    Rochester, NY
    Assuming you have the DC Brick? Been looking around and it appears the Iso-Brick won't start shipping u til June or thereabouts.
    In any case, it looks to be a solid solution to my needs without breaking the bank. Provided it is actually solid. I've heard a lot of good about the DCB, though some have called it a "glorified daisy chain." I've been using a OneSpot for over a year and will need to upgrade soon, so....
  6. Middleman
    MV, CA
    Yes, sorry, saw the picture and it looked the same. I have the DC Brick.
  7. FenderLover
    Minnesota
    I think it's likely they can, but not really my point...
    Glorified, but in a good way. Feeding power from separate circuits is more preferable over the Daisy Chain, which is what the 1-Spot is.
