Mxr brick
Discussion in 'Pedal/Effects Owners Clubs' started by casey2910, May 17, 2021.
Tags:
  1. casey2910
    casey2910 Tele-Meister
    arkansas
    Iso brick mini or the regular mini or the standard brick? Which one are most of you using. I'm mainly a home player
  2. J. Bonkosky
    J. Bonkosky Tele-Holic Silver Supporter
    Seattle Washington
    One spot pro CS7 is what I use. Or a electro-harmonix wall wart with a daisy chain depending on what board I am using. Your choice will depend on how many pedals and how much current you need. Analog pedals often need less current (there are exceptions) digital pedals will need more. The pedal manufacture specs will usually list current draw. This will be the best indicator for what power supply you need for your set up. Good luck!
  3. Haase
    Haase TDPRI Member
    Alabama
    I just got an mxr power supply and it does a great job on my pedal board. Very quiet and most importantly, it allows me to power my 18v pedals.
