Mustang trem
Discussion in 'Tele-Technical' started by Meshgearfox, Jul 31, 2012.
  1. Meshgearfox
    Meshgearfox Tele-Meister
    Montague, mi
    Have any of you ever mounted a Dynamic Vibrato on a tele? I'm thinking of placing it back further than its normal position and notching out the bridge and running the string over the existing saddles. It looks like I can get a break angle similar to a jazzmaster but i'm not sure it that would be sharp enough. Any thoughts or suggestions?
  2. twiggymac
    twiggymac Tele-Holic
    Massachusetts - United States
    looks freaking sweet!
  3. Meshgearfox
    Montague, mi
    That does look nice. Maybe i'll install the tremolo in the proper position and look for a plate to mount the bridge pup.
  4. twiggymac
  5. LocustPlague
    LocustPlague Tele-Holic
    Make sure you wrap the strings correctly on the mustang trem. The string goes through the retainer with the ball end pointed toward the neck, then you bend the string UNDER the tailpiece. Any other way and you will NOT get a big enough angle.
  6. Meshgearfox
    Montague, mi
    Thanks. I got the tremolo on a guitar ( in the loosest sense of the word) a friend gave me years ago. He had the strings inserted through the back side and then wrapped over the top and back around to come out under the tailpiece. It worked, sort of, but the the guitar was unplayable for a host of other reasons so I tore it apart and put the hardware in my "maybe i'll need this someday" box.
  7. Meshgearfox
    Montague, mi
  8. twiggymac
    pretty sure its chrome plated aluminum, but same thing! you could always buy a cheap bridge and chop off the bridge part. then you would have a tele bridge pickup plate, AND a half bridge!
