Musikraft Neck Questions
Discussion in 'Telecaster Discussion Forum' started by Smiff, Nov 16, 2017.
  1. Smiff
    Smiff Tele-Holic
    Is the Musikraft 2 piece construction neck with “Veneer Vintage Fender” fretboard option like the round-lam Fender fret boards of the 1960s?
    Also has anyone from the UK bought one? If so; what’s shipping and import charges like?
    Lefty Addams likes this.
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Slab_vs_Veneer.jpg Yes. The slab board is as described a slab, with no skunk stripe.
    Smiff likes this.
  3. Lefty Addams
    Lefty Addams Tele-Afflicted
    England
    So, from that, and not knowing the relevant history here, am I too summise that the Fender vintage slab board necks never had a skunk stripe? That is period correct, yes?
  4. telemnemonics
    The first slab board necks had no skunk stripe but Fender went back to using the skunk stripe pretty quickly and you will find the skunk stripe on slab board, veneer board and one piece maple Fender necks.
    Not sure how exact a Musikraft veneer board neck is to an original, I have a '64 thick veneer board Tele neck with no skunk stripe and a '72 thin veneer board neck with a skunk stripe. They are not really identical even aside from the fact that the skunk stripe is on one and not the other.
    Musikraft can probably answer better and will make any spec you ask for.
  5. BobbyMac
    BobbyMac Tele-Meister Gold Supporter
    Actually, the first slab board rosewood necks Fender made for Telecasters/Esquires did have a skunk stripe and a headstock plug, as Leo used up a supply of maple necks on hand that were initially spec'ed for all-maple construction. In fact, in the earliest literature advertising the new Custom Telecaster and Custom Esquires in 1959, you can see the headstock plugs quite clearly in the pictures accompanying the announcement of the new models.
    telemnemonics likes this.
  6. Redd Volkaert
    Redd Volkaert Tele-Holic
    Galax, Virginia
    Here's some dirt I found;
    In 69, the solid maple neck with skunk stripe returned on the Tele
    and 71 on the 3 bolt Strat
