After a four month wait, pretty much to the day, my neck is supposed to be delivered tommorow. I can't wait! I'm going to put it on my 1993 MIM Tele. I bought it new in '93 and have played this neck a lot. I modeled my new neck off of my EBMM Axis necks, so it will be all-around smaller than the original neck. I'm super excited. Here's what I went with;
Tele® Neck Custom Build
- Guitar Neck Build:
Qty: 1, Price: $195.00 - Construction Type:
1 Piece Constructed - Orientation:
Right for Right Handed Players - Scale Length:
25.5" Standard Fender - Number of Frets:
21 - Nut Width:
1-5/8" (41.3mm) - Nut Slot Style:
1/8" Nut Slot (Standard Fender) - Heel Width and Type:
2-3/16" (55.55mm) Squared Tele - Truss Rod Type:
Dual Acting w/4mm Hex Adjust @ Heel - Shaft Wood:
Roasted Light Figured Maple ($40.00) - Fingerboard Radius:
10" - Fingerboard Edge Style:
Semi Rolled Fingerboard Edges - Tuner Hole Size:
11/32" (Standard Kluson) - Top Inlay Type:
1/4" Dots (Black) - Side Markers:
Black 2mm - Side Dot Location:
Center of Fingerboard Wood - 12th Dot Spacing:
Wide (Vintage Style Pre 1964) - Fret Size and Type:
6150 Nickel Silver (Medium Jumbo) - Skunk Stripe Option 1pc:
Standard Walnut - Back Profile Shape and Size:
AYS 81 91 (EVH) - Binding:
NONE - Tuner Install:
NONE - Nut Installation:
Install Slotted TUSQ Nut ($35.00) - Finish:
Oil (Same Oil Fender Uses) ($60.00) - Neck Mounting Holes:
Drill Neck Mounting Holes Standard Fender Pattern - Total:
$330.00
