Musikraft Blackguard Neck - Truss Nut?
Discussion in 'Tele Home Depot' started by r_o_b_s_o_n, Dec 11, 2018.
  1. r_o_b_s_o_n
    r_o_b_s_o_n TDPRI Member
    Victoria BC, Canada
    Hello,
    I'm about to place an order for a Musikraft Blackguard Neck(1739), and have a question about their options?
    The list a difference in "Truss Nut" - either "Single Slot" or "Dual Slot".
    Can someone explain the difference? is it simply the truss rod adjustment at the heel of the neck? One looking like a phillips head screw, and the other like a slotted screw?
    Thanks for the clarification.
    acrylicsuperman likes this.
  2. acrylicsuperman
    acrylicsuperman Tele-Afflicted
    Arizona
    Flat head or phillips head.
    The early blackguards screws were slotted, the later ones progressed to phillips. Juat depends on your preference or era you are aiming for.
  3. r_o_b_s_o_n
    Victoria BC, Canada
    Sorry, not the pickguard screws.... but the Truss Nut.
  4. Hexabuzz
    Hexabuzz Friend of Leo's
    Northeast PA
    That's what @acrylicsuperman is referring to... the truss rod adjustment screw.
    It's either going to have one slot, dividing it into two half circles, as the vintage style was, or 2 slots in a cross pattern.
    Both work the same, it's just really an aesthetic choice.
  5. Hexabuzz
    Northeast PA
  6. acrylicsuperman
    Arizona
    That's what I meant, as Hexabuzz pointed out.
    When I said screws, I meant all of them.
    Hexabuzz likes this.
  7. guitarbuilder
    One is slotted for a straight screw driver, the other is + shaped for easier/ finer adjustments I'd guess. I'm not sure that a phillips screw driver fits in there easily without damaging the nut slot. They'd probably call it phillips in the list if it were one. :)
  8. Hexabuzz
    Northeast PA
    You don't use an actually Phillips head, but a straight driver. There just happen to be 2 slots so you can take your pick of which one to use.
    It also probably made it a bit easier to access a slot without loosening the neck to adjust the truss rod, considering the positioning at the neck heel, and the limited access with the pick guard attached.
  9. K-Line
    K-Line Tele-Holic Vendor Member
    St. Louis, Missourah
    Go for the philips head or double. Gives you more angles of attack when adjusting the truss.
