Mounting Tubes Horizontally??
Discussion in 'Glowing Bottle Tube Amp Forum' started by Rufus, Dec 17, 2019.
  1. schmee
    schmee Doctor of Teleocity
    I seriously doubt there's any problem with any orientation. I used to play with my bassman head standing on end a lot due to cab tilt and stage space available.
  2. artdecade
    artdecade Poster Extraordinaire
    Boggo Road
    No problems with horizontal tubes.
    ruger9 likes this.
  3. beninma
    beninma Friend of Leo's
    Earth
    Orange has production amps with the tubes oriented horizontal pointing towards the front of the amp. There's a vent on the top of the amp in front of the controls.
    The Rocker 15 & Rocker 32 Combos are set up this way.
    I do think in Orange's case it's about a layout that can just be flipped in the combo vs head design. When you take the chassis out of the amp to work on it and orient it so the tubes point up the controls are sitting there on the side in front of you.
    Oh on these amps all the tubes are fully held in place by metal shields/supports so gravity would not be straining the glass/socket, only stress on internal elements.
  4. willc68
    willc68 TDPRI Member
    philly
    B96A1B69-9A47-42FB-99D5-C99E49BC5868.jpeg My Silvertone 1482 has the tubes mounted horizontally on the chassis.
    I really can’t think of any reason this would cause problems.
    This amp well over 50 years old and it has held up very nicely.
  5. 5595bassman
    5595bassman Tele-Holic
    Montreal Canada
    Peavey Bravo Teal Stripe era had horizontal tubes.
    DADGAD, nixdad and MrGibbly like this.
  6. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    RCA tube manual is great, I've got a few from different years. But does that data mean much with the tubes made today?
    That said, I've been running JJ EL34s sideways in an old 1987 in a tweed high power Twin cab for some time now.
  7. El Marin
    El Marin Friend of Leo's
    Madrid, Spain, EU
    My Princeton clone is horizontal as well. I just installed some spring tube retainers and it is working two years ago, 60 gigs and hundreds of 5 hours rehearsals
    Not a problem ever... so far
    BobbyZ likes this.
  8. jtcnj
    jtcnj Tele-Holic
    N.J. USA
    The 18w TMB (el84) I built a few years ago is oriented controls up tubes down when mounted in cab.
    I didn't have a cab built and played it a lot for at least a year laying flat / tubes horiznontal with no ill effects.
  9. jrblue
    jrblue Friend of Leo's
    Santa Barbara
    You can do it but it's sub-optimal from a durability standpoint since the structure inside the tube is not designed to support parts that way. You can probably get away with it, though bumping amps around is bad for tubes to begin with and a horizontal mount just makes it a bit worse.
  10. Bob Womack
    Bob Womack Tele-Afflicted
    Between Clever and Stupid
    Yep, and here's the proof:
    This is one of the original Svetlana EL-34s that hung horizontally in my Marshall JTM-612:
    ...It overheated after over twenty (20) years(!) of service.
    Bob
    Wally and BobbyZ like this.
  11. Alamo
    Alamo Doctor of Teleocity
    Berlin
    Hmm, well twenty years can get a little long in the tooth, no? :)
  12. LOSTVENTURE
    LOSTVENTURE Tele-Afflicted
    Charlotte, NC
    As far as heat dissapation is concerned, horizontally is actually better than base down, and much better than base up, which is what Fender usually does. ?????
  13. Shiney Strings
    Shiney Strings TDPRI Member
    Derbyshire, England
    Marshall pre JCM 800 combo's shared the same chassis as the heads which rendered the tubes horizontal in the combo cabinet. I never heard of a bluesbreaker having horizontal mounted tube issues!
    BobbyZ likes this.
  14. teleman55
    teleman55 Tele-Holic
    fox lake, il
    I've got a Crate V30, tubes are all horizontal. 4xEL83, 3x12AX7. Played a lot of gigs with that, so it's been banged around. It's got a vent on op.
  15. MrGibbly
    MrGibbly Tele-Afflicted
    SATX
    Peavey Bravo had horizontally mounted preamp and power tubes that were also enclosed in a little metal box with a fan moving air across them.
  16. Ringo
    Ringo Poster Extraordinaire
    Memphis TN
    There were several Peavey amps that had horizontally mounted tubes, the Triumph amps (though they seemed to have reliability issues), early tweed Peavey all tube amps and maybe some others.
  17. totenkopf13
    totenkopf13 NEW MEMBER!
    Marshall JCM 600
  18. Guitarteach
    yep... my JMP combo been going issue free since 1979 with horizontal tubes
    BobbyZ likes this.
  19. clintj
    clintj Friend of Leo's
    Idaho
    Ok, let's run through some common tube types from their data sheets. I searched until I found a sheet with info on what mounting positions are allowed.
    RCA 12AX7: any
    RCA 6L6GC: any
    Amperex EL84: any
    TungSol 6CA7: any
    TungSol 5Y3GT: vertical, or horizontal if pins 2 and 4 are in a vertical plane
    Sylvania 5U4GB: vertical, or horizontal if pins 1 and 4 are in a vertical plane
    GE 5AR4: any
    Sent from my Pixel 2 using Tapatalk
    old wrench and Nickfl like this.
  20. teletimetx
    teletimetx Doctor of Teleocity
    Houston, TX
    Early 60's Knight 3245 - a 45W two by 6L6, mounted horizontally, still alive & kicking.
