Mooer Mini Preamp #014 Taxidea Taxus ,Faux Suhr Badger
Discussion in 'Modeling Amps, Plugins and Apps' started by ping-ping-clicka, Nov 14, 2019.
  1. ping-ping-clicka
    ping-ping-clicka Tele-Holic
    left coast
    My little preamp is turning out to be a wonderful sounding mini marvel
    The Dreaded swarm of buzzing yellow jackets zzzzzzzzzz edge is not there at all, a smooth gourmet grind , think JCM 800. The clean tones are a rich resilient punctual affair, money well spent for the tones delivered.
    gkterry likes this.
  2. navigate40
    navigate40 Tele-Meister
    SE FL
    I have the Mooer 006 Fender like preamp. It is amazing. They got it just right. I also have an IR loader pedal that has Fender amp IR's....not nearly as good.
    It has an interesting feature...apparently, it is actually TWO amp sims. The second one is a Marshal (I think) and does distortion. Great controls, including 3 band eq.
    If I were to play out through a PA, I would not bring an amp...I would just use this.
  3. Thin white duke
    Thin white duke Tele-Afflicted
    italy
    Hi, does the Mooer 006 have a good clean headroom ?, i'm interested in that model, also what is the IR loader pedal with the Fender amp that you have ?
    Thanks a lot....
  4. navigate40
    SE FL
    Hello - hope this is not a hijack, but...for info.
    I think the Mooer 006 does have good clean headroom...but...have not really pushed it.
    The IR loader I have is the NUX Mini Studio. It works well and is easy to load new IR's. Less expensive than the Mooer Radar, but only 8 slots. And I think the Mooer has more settings that can be changed....not sure.
  5. Thin white duke
    italy
    Ok thanks a lot, i was about to buy the Solid Studio as well but the big one, i like the fact that it's got the power amp sim and the xlr out, also the mini sounds good from the videos though.
    Thanks....
