Monoprice 15 watt amp upgrades
Discussion in 'Amp Tech Center' started by Stewtech, Aug 22, 2019.
  1. Stewtech
    Stewtech TDPRI Member
    Couch
    Are those American tubes RCAs?
  2. Keefsdad
    Keefsdad Tele-Holic
    Toronto Canada
    Can't remember, possibly.
    Stewtech likes this.
  3. boredguy6060
    boredguy6060 Friend of Leo's
    Sou Cal
    The speaker will cause the most dramatic change in sound over any other components.
    More than tubes or caps or cabinets. If you want to drastically change the sound of your amp, change the speaker.
    dougstrum, schmee and Stewtech like this.
  4. Stewtech
    Couch
    Absolutely, now I just have to figure out which speaker will release the sound I want. I was thinking between Eminence, Weber or Jensen? Do you have any suggestions for a full American sound? Going to be playing anywhere from bluesy, chicken pickin, to Jazzy.
  5. Pontiaddict
    Pontiaddict TDPRI Member
    Central Florida
    Quick question, is V1 closest to the power tubes? Or farthest away?
    After reading page after informative page of mods for the Monoprice SR amp; some say the V1 is closest to the EL84s, however the YouTube video by D. Braun says V1 is farthest away from the power tubes.
    I’m confused and hoping to find more clean head room.
    Mods to date, replaced all tubes: JJ’s 5751, 12AX7, 12AX7, JJ EL84 match set.
    TYIA
  6. VintageSG
    Yorkshire
    Furthest from the power valves/closest to the input socket. Think of the valves in the order the signal goes through the amplifier.
    Stewtech and Pontiaddict like this.
  7. Pontiaddict
    Central Florida
    Thank you.
  8. Stewtech
    Couch
    I always thought V1 is furthest away from the power tubes?
  9. Pontiaddict
    Central Florida
    You are correct.
    That’s what VintageSG replied above, farthest from the power tubes.
    In my amp I installed a 5751 in lieu of the 12AX7 hoping for more clean headroom... the amp still breaks up before gain reaches 2, which leaves me still trying to coax a bit more clean headroom.
    Listening in on your thread thinking I might try a speaker swap to tame the break-up for my style. GA SC64, Creamback, Cannabis Rex or? It’s a tough decision, making something good, better.
  10. Pontiaddict
    Central Florida
    Although I too have the itch for a new speaker/voice, two things I read today that, for me, are worth trying before a speaker swap. YOMV
    1.) 12at7 in V1.
    Reading the at7 is 60%<12ax7, the 5751 is 30%<12ax7 my guess is the lower pre amp power might help with the early break-up. Some say the difference is negligible, others thought it was notable.
    2.) Another forum suggested simply using the controls differently:
    Stewtech and Telecaster88 like this.
  11. Stewtech
    Couch
    I was looking at the Creamback and the Rex but they seemed like overkill with wattage, so I was thinking Jensen C12Q since it’s 35 watts. I looked on a couple old speaker threads of fender players and a few said this option was there choice. Although another fellow said that the Eminence Maverick with the built in attenuation was ok. Do you know if the Monoprice amp is 15 watts if adding a speaker that is 50+ watts would give you more headroom or what exactly that would do to the sound?
  12. Stewtech
    Couch
    I think both the tube and the volume trick are definitely going to be on my list to try. Are you re-biasing your amp with ever tube swap?
  13. Pontiaddict
    Central Florida
    No, not on the pre-amp side, it’s not necessary.
    I did replace the EL84s with a matched pair, but the pre-amp tubs afaik can be swapped with no effect.
    Edit:
    Remember, the stock speaker is rated at 70 watts
    Skydog1010 and Stewtech like this.
  14. Skydog1010
    Skydog1010 Tele-Holic Ad Free Member
    North Carolina
    What am I missing? I just got mine today and truly could not be happier! Just the way it is... I'm absolutely positively Goofy over this amp. Break up is perfect. Mine is clean as a slate roof pointed south in southernmost UK, with gain dropped off and tone cranked up.
    I really don't understand why someone would want to mess with it?
    What am I missing?
    Keefsdad, bsman and Stewtech like this.
  15. Stewtech
    Couch
    That is a plus, I think I am going to try a few different combos with the pre, I read that you should be able to exchange them with 12au7 and they might have the lowest gain... Definitely gonna get the JJ’s.
    Actually I always thought the seventy 80 was 80watts... I would think that a speaker more relative to the amp wattage would give a more focused, smoother tone? I do know that the fender blues junior has a 50 watt speaker and some decent headroom. I have been emailing Weber and it sounds like their Ceramic Blue Dog with light to medium doping and a wattage option. The 50 and 75 watt speaker sound clips sound sweet in a fender. https://www.tedweber.com/blue12f
    Pontiaddict likes this.
  16. Pontiaddict
    Central Florida
    Personally it’s just a matter of tailoring tone, it is great as-is agreed... however those I’ve heard with simple modifications were noticeably better.
    My quest is for a fatter tone, with smoother highs, reminiscent of my favorite amp from years ago. With the low entry price point of the Stage Right amp I can experiment within a reasonable budget and hopefully attain that goal.
    Not intending to diminish the product in any way, just personalize it.
  17. Stewtech
    Couch
    I am glad to hear you are happy, I also thinks it’s a great amp! I just love to upgrade whenever possible and tweak to get different sounds for different situations. I am using this amp for daily use but also for experimenting.
    Pontiaddict and Skydog1010 like this.
  18. schmee
    schmee Poster Extraordinaire
    Well crap, My mono 15 has been sitting a month. Tried it yesterday and nothing but a garbled very low volume sound! Was fine when last played!
  19. Stewtech
    Couch
    Sorry to hear that. Can you return it?
  20. schmee
    Nah, it's the older model. I'll have to get it open and check it out, but I've been considering just modding it into a new small amp. I just dont trust it to gig with it and could use a ~15 watt amp in the arsenal. If I keep the transformers it should be fairly low wattage. Some possibilities:
    -Stick with EL84's; Carmen Ghia clone
    -Go to 6V6's; Princeton Reverb clone.
    -18w Marshall clone? AC15 CLone?
    I dont really need another 6V6 amp though, although that's my tone preference usually. Maybe a lower wattage Princeton would be good... hmmm
