This should not be hard but I'm having trouble getting my head around it. I have:
Behringer UMC1820
Various hardware synths (Yamaha Mult12, Roland JV-880)
Modeler (Headrush MX5)
Monitor speakers (JBL305p)
And since the JBL's aren't terribly loud, id like to be able to run the MX5 and Multi12 into a Headrush 108 (maybe with a sub eventually for the Multi12). The drum kit, and vocal mic are away from the JBL's, plus I practice at the wedge to practice close micd singing while playing guitar at the same time. So I like to record that way too.
I have a patch bay which may be of help here but it's not currently in use. most of the time the electronic sources just go to a submixer. If I want to print drums or keys to audio tracks, I can bounce that. So far so good.
But the MX5 is recorded live, so I don't really want it in the 2 ch mix going into tracks 7/8. Or rather I don't want everything from the submixer going into 7/8 with it. I believe it's the only source with this problem. Vocals, acoustic guitar are also live, but don't rely on monitoring to be heard. Any midi sources are recorded as midi and bounced to audio tracks as needed.
After laying all this out (there was a story in college about explaining your problem to a giant teddy bear outside the ta's office before you could ask for help), I think my solution is to use the patch bay send (without the return breaking the path) to plug the MX5 to its own tracks on the interface inputs during tracking, and the submixer going into 7/8 might be unnecessary as well. (Do the same during bouncing for midi sources) That way the submixer is for monitoring only and handles the two separate monitoring systems.
Should I be making better use of the patch bay? Like at least interface inputs 2-8 picking off the patch bay return? (1-2 are on the front panel and have mic pres. I know the trs inputs are balanced but I think they skip the mic pre. So I might keep 1-4 available for mics. ) I'm not sure I need it but I have it and it's a behringer patch bay. It's probably more valuable as a doorstop than trying to sell it.
Behringer UMC1820
