Momentary hum on power-up
Discussion in 'Amp Tech Center' started by tillamook, Jun 12, 2021.
  1. tillamook
    tillamook TDPRI Member
    Hello:
    About 15 seconds after I turn on my new Vox AC10 it begins to hum, the hum increasing and then decreasing over a period of 30 seconds, then everything is OK although it may be that the low level idle hum has increased a little over the 2 1/2 weeks I've had the amp.
    Is this likely a faulty tube problem? The amp shipped from Sweetwater to the coast of Oregon, it may
    have gotten bounced around a bit.
    Thanks in advance for any help,
    Bill
    Astoria, Oregon
  2. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. Great Britian.
    I would replace the two EL84s/6BQ5s with a balanced pair.
  3. Wally
    Be watching your power t7bes when you fire the amp up. Is either one redplating at any point?
    I would not want any new amp that does this unless a tech checked it out. It well may be that the tubes are not draw8ng the same current and a new, matched set would cure the problem as Jon says….or it could be another problem that is causing the mismatched current draw. W
  4. tillamook
    Thanks Wally and John:
    I have a new tube set coming on Tuesday, I'll see what happens. I can't see the tubes without taking the back off so I think I'll wait
    until Tuesday to check for redplating.
    Wally likes this.
  5. ThermionicScott
    CID
    Maybe one of the EL84s takes a little longer to warm up? I'll be interested to hear the rest of this story!
    Lowerleftcoast likes this.
  6. Jon Snell
    Armed with the information given by tillamook, an unballanced valve is the most likely cause.
    It could be as simple as one has the heaters is in a slightly different position regarding heat conduction to the cathode and is perfectly acceptable as long as it catches up with the other valve soon after power up.
    If it was a new machine, I would insist of a set of balanced EL84s FOC as a replacement as it will be under warranty and effectively faulty out of the box.
  7. soundchaser59
    soundchaser59 Tele-Afflicted
    Up The Creek
    This.
    And if I know sweetwater from previous experience they would not balk at such a request.
  8. tillamook
    I'm sorry to disappoint those waiting for an exciting resolution of the mysterious hum problem but I boxed up the amp today and it's on it's way back to Sweetwater.
    I was right on the edge of the return window and did not want to be without an amp while dealing with a potential repair or swap. It's a week and a half shipping time from Sweetwater to the Oregon coast.
    A side note: Sweetwater informed me that swapping the tubes myself would void the Vox warranty. I guess you could always be a sneaky criminal type and not tell them.
    I made the drive into Portland yesterday and picked up an AC15C1X (Alnico Blue loaded), Yowza!
  9. ThermionicScott
    CID
    That the story has a happy ending is good enough for me! Congrats on the AC15. :cool:
  10. schmee
    Do they have a rectifier tube? A couple of my vintage amps do that until the rectifier warms up. Then they get silent.
  11. tillamook
    No rectifier tube in the AC10.
    Thanks, the AC15/Blue is perfect with my current favorite, a flatwound strung Gretsch hollowbody.
