Mojotone 5E3 Voltage Question - V2B Pin 8
Discussion in 'Amp Tech Center' started by peterferguson9, Nov 4, 2019.
  1. peterferguson9
    peterferguson9 TDPRI Member
    Nashville, TN
    First time poster on this forum. First time amp build as well! Calling amp techs/5E3 kit experts:
    Started putting together my first amp, a Mojotone 5E3, about a month and a half ago. It has been an awesome experience, and I can't wait to do another. I've got a Celestion Gold for this rig and I think it is going to be rad.
    The amp is fully together, and everything seems to be testing within tolerance except for one thing - V2B Pin 6 and 8. Pin 6/V2B Plate/Phase-inverted output is way too high, and Pin 8/V2B Cathode/non-inverted output is way too low.
    When I plug a guitar in, I have..sound. No hum, no buzz, but it kinda sounds like a low-biased gated fuzz pedal. Super distorted, not too loud, and very glitchy. In other words, it sounds REALLY cool...but REALLY wrong.
    Things I've tried, with no changes to the problems:
    - Confirmed continuity from the .022uF coupling cap to the PI inverter grid leak
    - All resistors in the cathodyne (1M, 1.5k, 56k) all test to spec.
    - Confirmed that the export lines form the PT are properly insulated and tucked away
    - Confirmed wall outlet is 120VAC.
    - Swapped 12AY7 and 12AX7 (V1/V2).
    - Tried another working 12AX7 in V2.
    Here are the tested voltages across the amp:
    V1:
    Pin 1: 136VDC
    Pins 2/7: 0VDC
    Pins 3/8: 2.1VDC
    Pins 4/5/9: 6.1VAC (2.9 to ground)
    Pin 6: 129VDC
    V2:
    Pin 1: 162VDC
    Pin 2: 0VDC
    Pin 3: 1.4VDC
    Pin 6: 242VDC
    Pin 7: 3.7VDC
    Pin 8: .02VDC
    V3:
    Pins 2/7: 6.1VAC (2.9 to ground)
    Pin 3: 356VDC
    Pin 4: 332VDC
    Pins 5/6: 0VDC
    Pin 8: 24VDC
    V4:
    Pin 3: 344VDC
    Pin 4: 332VDC
    Pins 5/6: 0VDC
    Pin 8: 24VDC
    5Y3:
    Pin 2: 361VDC
    Pin 4: 355VAC
    Pin 6: 355VAC
    Pin 8: 362VDC
    Photos of the build: 5EA69187-243F-4F8C-AF14-D222F5DA41CD.jpg 16C3D7A9-76ED-4C6F-9F0B-1CA79DEF1179.jpg 20A658D1-51DC-4F0F-A9C9-5093B6445236.jpg B6DA363C-69CC-497A-BDD9-B59AF7234F27.jpg E13FC8F3-193D-49FB-A4C3-FD1749DC0D7A.jpg FB826903-EDA7-485E-A23B-6653A5EA123E.jpg
  2. corliss1
    Lansing, MI
    Measure resistance from that pin 8 to ground. What do you get?
    King Fan likes this.
  3. muchxs
    muchxs Doctor of Teleocity
    New England
    Recently repaired one with symptoms almost exactly like that. Blown output transformer.
  4. King Fan
    Salt Lake City
    I know this isn't about the rectifier, and it may be a typo, but shouldn't pin 2 be 5VAC? Is it odd your B+ at pin 8 is only 362VDC if your PT secondaries are at 355VAC? Is the low 6.1 heater voltage on modern wall voltage a sign of the same thing?
    I'm guessing (and hoping) @corliss1 is onto something with the grounding question.
  5. peterferguson9
    Nashville, TN
    @corliss1 @King Fan @muchxs
    Thanks for your responses. I found the issue and am almost embarrassed to explain! I quadruple checked my wiring during the build, and thought everything was fine. Turned out my lines for pin 7 and pin 8 were switched. Such a simple mistake. Switched them back and the amp roars! Already using it on overdubs and live.
    Looking to redeem myself on another build - either a Princeton non-verb or brownface deluxe. Really addicting stuff!
    D'tar and King Fan like this.
  6. corliss1
    Lansing, MI
    You think you're the first guy that's switched the wire on a pin? :D
    My point for measuring that was "is pin 8 grounded." If you measured something other than the correct value there, that's a clue, and after you've been looking at something for a while a good measurement is often more helpful than a quadruple visual check.
  7. peterferguson9
    Nashville, TN
    Should have mentioned - I checked that value, which led me to follow that wiring again, which led me to finding the problem!
    corliss1 likes this.
  8. Preacher
    Preacher Friend of Leo's
    Big D
    Been there, done that!!
