Modifying Strat Neck Pocket for Tele
Discussion in 'Tele-Technical' started by wierzbowski, Aug 9, 2019.
  1. wierzbowski
    wierzbowski Tele-Meister
    Sulaco
    Is it as easy as using a forstner bit to drill out the 'mickey mouse ears' on the corners?
  2. Deaf Eddie
    Deaf Eddie Friend of Leo's Silver Supporter
    Beautiful Idyllwild, CA
    Yup. If you have one of those overhanging 22 fret necks, it hides poor workmanship.
    It's POSSIBLE that the rout is not necessary - IF your bridge has an extra 1/8th inch throw left, to compensate your intonation...
  3. wierzbowski
    Sulaco
    Thanks for the response, I'm looking at modifying a Warmoth body, but its unpainted. Hopefully the pickguard and paint will make it look cleaner
  4. thesjkexperienc
    thesjkexperienc Tele-Holic
    Colorado Mountains
    Usually you can just bolt a tele neck to a strat but not the other way around.
  5. TRexF16
    Tucson
    Yeah, if the pic you posted in the OP was the strat pocket you're talking about, proceed with great caution. My guess is there is no wood that needs removing and you might be wishing you had a little more wood there (aren't we all??:lol:)
    Think about it. The radius of the strat neck's heel makes it a bit longer than the tele, needing a slightly deeper pocket. The 1/4" radii at the corners of both the strat's and the tele's neck pockets should be in the same relationship to the bridge. That is why you can bolt a tele neck in a PROPERLY FIT AND ROUTED strat pocket and it still intonates normally, but not the other way around.
    Now look back at the photo in your OP. Note how different is the way the heel of a strat neck fits into that pocket than would one that was routed right, like this:
    I think that shows why you don't want to take any wood off that body.
    Then again I could be completely full of beans, so maybe somebody else can comment.
    Just be careful and think it all through before you cut.
    Cheers,
    Rex
  6. wierzbowski
    Sulaco
    Thanks for the input, but there is some inaccurate information being shared. Tele neck pockets can accommodate both types of necks, but Strat pockets can only fit Strat necks. I want to modify a Strat neck pocket. Here are some pictures and info from the Warmoth site
    Jim_in_PA likes this.
  7. TRexF16
    Tucson
    Well, I can't argue with Warmoth, so I stand corrected. I would never want to put out bad info. I'm going to have to take some measurements to confirm Warmoth's position.
    That said, I stand by my advice that I think you do not need to remove ANY wood from that neck pocket you posted the pic of.
    Cheers,
    Rex
  8. fenderchamp
    fenderchamp Friend of Leo's Ad Free Member
    omaha
    I mounted a tele neck on my warmoth strat body. I did take some wood out of the corners of the pocket.
