Modeling Forum Community Posting v2
Discussion in 'Modeling Amps, Plugins and Apps' started by jaytee32, Feb 15, 2018.
  1. jaytee32
    jaytee32 Tele-Meister
    Netherlands
    Hi *,
    This is the second version of the Modeling Forum Community Posting.
    The intent of the post is to help in discussions between the differences between the terms "solid state", "digital", "emulator", "modeler", "profiler" etc. The post below is the summary of discussions involving a number of TDPRI people, please refer to the discussions on the first version of the post
    http://www.tdpri.com/threads/modeling-analog-digital-solid-state-community-posting.578753/
    and to the original threads
    http://www.tdpri.com/forum/modeling...1482-modeling-analog-digital-solid-state.html and
    http://www.tdpri.com/forum/modeling...-emulating-digital-solid-state-draft-2-a.html
    to see the cast of characters contributing.
    If you have a strong disagreement with the post, it is useful to browse through those original discussions as your disagreement has almost surely been discussed at length. A lot of the disagreements boil down to differing points of view on ill-defined terms like "modelling".
    Here goes, hope this is helpful especially to newcomers!
    There's a lot of confusion surrounding the terms listed in the subject. For example we see posts confusing "solid state" with "digital" and "emulation" with "modeling". This post tries to clarify that confusion for the benefit of anyone reading.
    First let's talk about the terms that are well defined.
    1) solid state: this is a pretty old fashioned term actually, all it means for the purposes of amplifier discussions is : no tubes. Technically it means that all the electronic components are constructed out of solid materials. Vacuum tubes are of course not solid -- that's the distinction. Solid state doesn't mean anything else except "no tubes". "Transistor" amps are solid state amps (as long as they don't contain some tubes too, in that case they are called "hybrids").
    2) analog/analogue and digital : analog circuits work on an incoming signal as a continuous value, and the various pieces of the circuit work in the same way. Digital circuits work basically on numbers, doing operations on those numbers. For a guitar amplifier, the input signal is converted to a sequence of numbers, then inside the amp calculations are performed on those numbers resulting in an output signal.
    Analog vs digital is not strictly related to solid-state/transistor/tube. All the combinations are possible, although digital tube amp (all tubes, no transistors or chips) would be as big as a house. There are even hybrids out there that have for example (the Vox Valvetronix) a tube-based analog preamp and a digital modeling section.
    In this post, we focus on digital modeling amplifiers since this is the digital forum (but see the final section for a couple remarks on this). Digital modeling amplifiers work by converting an input signal at some point to a stream of digital values, doing computations on this input signal, converting the processed signal back to analog so it can drive a speaker (or line out jack). The computations done are designed so that the analog output (or sound coming out of the speaker) sounds like a guitar coming out of a real amplifier, in most cases out of a specific amplifier like at 57 Twin, Vox AC30, etc.
    Manufacturers don't in general tell you exactly how their products are doing the calculations. There are a couple of known cases, and the others most likely work more or less in the same way.
    • One way to do it is to have software that responds to a digital input signal in the same way that a component would respond to the corresponding analog signal. Now if you have such software for tubes, capacitors, resistors, etc, you can connect them all together so that you have a software version of a tube amp's circuitry, and in principle this software "model" of the amplifier will react to a guitar input signal the same way as the real amp. A specific example of an amp that does it this way, at least partially, is the Blackstar ID TVP series (you can dial in which output tubes are "used").
      • The challenge in this approach is that a real tube or transformer is a complex thing that responds in a different way depending on a bunch of factors; manufacturers will likely make compromises in how realistic the software is, to keep costs down.
    • Another approach, taken as far as we know only by the Kemper Profiler, is to figure out what the software model should be by direct measurement. So instead of calculating the response component-by-component, their software directly (via a microphone) measures the end-to-end response of the entire amplifier.
    The calculations are often (always?) done in both cases by fast DSP (digital signal processing) chips.
    We had a lot of discussions here about various terms such as "profiler", "emulator", and "modeler". Profiler is pretty easy, see above ... so far as we know there is only one of these (the Kemper) so definition is easy in this case.
    We "decided" that an emulator was best defined as an amp that tries to recreate one or more specific amplifiers by making "virtual circuits" that are identical to the target amp's circuits. Examples are the Blackstar ID TVP already mentioned and the Fender Cyber Twin.
    The toughest definition is that of a modeler. The best "definition" we could give this is, any amp that can be configured to "sound like" multiple other amps, or that allows you to construct a very wide range of specific tones, by choosing different combinations of settings. Some objected that the profiler should not be called a modeler, saying a profiler works with a profile and a modeler with a model; on the other hand, in both cases the intent and much of the technology is the same.
    Hope this post helps further understanding and useful discussion in this forum!
    Appendix
    We don't include analog amps in this forum, we do mention that analog modeling amps do exist, in the sense that the intent in those cases is to recreate, or at closely resemble, sounds specific to other amps:
    • The Tech 21 Trandemark amps are based on the Sansamp pedals, which the company labels as "analog modeling" ... the "calif/british/tweed" switches on these analog amps have essentially the same purpose as the "Black Panel", "Brit Combo" and "Tweed" selector on a (digital) Roland Cube.
    • The Peavey Transtube circuitry is analog, but designed specifically to reproduce how a tube circuit responds, just like the Blackstar TVP does in digital software
    • One could take this to the extreme and even claim that an Egnater Tweaker could be called a modeling analog tube amp, given its switches "vintage/modern" and "usa/ac/brit"!
  2. bluescaster72
    bluescaster72 Tele-Holic
    pennsylvaina
    Well Honestly not sure it needs defined too much . Modeling can either built into an amp or in the form of external processor such as a Boss ME 80 or other such modeler . Analog typically doesn't have modeling built in, but can have multiple channels including various gain channels, spring reverb and Chorus .
  3. jaytee32
    Netherlands
    You know, when I was getting ready to hit "post" or whatever that button was called, I kind of asked myself the same question. Seems like the discussions in this forum have changed a lot since we made that post.
    What triggered me is the recurrent discussions about whether the Katana is a "modeling amp". In that discussion is does matter how you define modeler. If what "digital modeling" means is "trying to recreate a specific amp in software" than you could make a case that the Katana is not a modeler, at least not the main voices (the sneaky amps is a different story).
    On the other hand, if "digital modeling" means creating various amplifier voices via digital algorithms, then the Katana is definitely a modeler, as is the Kemper profiler. Anyway, the marketing hype seemed to be intended to distance the Katana from other modelers like the Mustang, CODE, etc, the Katana was somehow better because the others are "just modelers" and the Katana has its own voices. Even though the technology is the same.
    Kind of like saying a Egnater is better than Twin Reverb because it's not trying to sound like a Twin Reverb :)
    Maybe that's a better target for the post if a v3 ever shows up.
    Cliffyg62 likes this.
  4. Jim Dep
    Jim Dep Friend of Leo's
    New York
    If a Katana has its own voice, can we expect to see a future modeling amp have a Katana preset ? Somehow I don't see that happening. o_O:)
  5. olefudd
    olefudd Tele-Meister
    out yonder!
    Didn't we have this same conversation about 5 or 6 years ago about the Mustang III ?
    kuvash and jaytee32 like this.
  6. Allthesound
    Allthesound Tele-Afflicted
    Connecticut
    Both Fractal Axe FX and Helix are modelers in every sense of the word , both model various amps from past and present manufacturers. Both also have amps models created exclusively by them that never existed in physical form. They are no less considered amp models than the former.
    jaytee32 likes this.
  7. jaytee32
    Netherlands
    I'm still waiting for a modeling amp that has a Peavey Bandit model.
    Walter Violette and kuvash like this.
