Modding my V18
Discussion in 'Shock Brother's DIY Amps' started by iansmitchell, Mar 22, 2009.
  1. iansmitchell
    iansmitchell Tele-Afflicted
    Gainesville, Florida
    What I want to do:
    • Change power tube sockets to 6v6
    • apply SLO mods
    • covert amp into standalone head with knobs on the face of head
    • remove reverb and repurpose reverb knob
    • Add a variable gain cut with seperate volume when on activated(similar to V33's clean "channel"
    What I already know how to do:
    • change amp into stanalone head
    • Do the resistor swaps and other things associated with SLO mods
    • Change PCB parts over to P2P(necessary to change tube socket type)
    What I need help on:
    Gain cut circuit, removing reverb parts, using the reverb knob for a separate "clean" volume control.
  2. iansmitchell
    bump!
  3. celeste
    celeste Friend of Leo's
    Maryland
  4. iansmitchell
    Thanks!
    Would it be possible to use the send and return jacks from the reverb as an effects loop?(using RCA->1/4" jack adapters)
  5. celeste
    Maryland
    I do not see the point of using send, as it would do the same thing as the line out, it would just have one more op amp buffer to go through.
    Yes the recovery can be reconfigured as a FX return. I am going to guess that the gain would need to be lowered and that you would want none or different frequency shaping.
  6. iansmitchell
    Understood!
  7. iansmitchell
    bump
