Modding my Blacktop Tele
Discussion in 'Tele-Technical' started by Thales, Jan 19, 2021.
  1. Thales
    Thales TDPRI Member
    Brazil
    Hey tele-people! Currently i dismantled my tele for a repaint. I love this guitar but it has always been sort of boomy, no matter what humbucker i put on it. Currently it has a Lollar El Rayo in the bridge, after a whole bunch of pickups i tried on it, so i am kind of sure that the pickups are not the problem, so i started thinking about pickup placement and measured the distance from the fully intonated low E saddle to the pickup pole piece and it measured 1,5" (4cm). Then i measured the distance of my SG and it measured 1,3" (3,5cm). The same pickup in those two guitars sounds very different. In the SG it sounds much more agressive, so i got my chisel and took 0,1" (0,5cm) from the rout, but i'm wondering if i should take an extra 0.1" (0,5cm) from it before i refinish the guitar. I love a bright guitar, so personally i think it would work, but i have my doubts. Any thoughts? Is 1,1" (3cm) too close to the bridge? Would it have some weird resonant problems?
    Sorry for the long text.
  2. Thales
    Thales TDPRI Member
    Brazil
    Disclaimer: I'm aware those guitars have different scale lengths and construction.
    boris bubbanov likes this.
  3. dogmeat
    dogmeat Friend of Leo's
    Alaska
    if you haven't done so, change the pots to higher values. thats the first thing I'd do
  4. cfreddy813
    cfreddy813 TDPRI Member
    Indiana
    Low pickup height creates "boomier" sound. Get the pickup closer to the bridge and it will be brighter and more agressive.
  5. Blues Twanger
    Blues Twanger Tele-Afflicted
    NYC and VT
    That's not a terribly big amount of movement IMO, the change would probably be very subtle.
  6. Thales
    Thales TDPRI Member
    Brazil
    Thanks for the replies everyone! I've done it! Changing the pots wasn't a option bcs the pikcup was connected directly to the bridge. Anyway, it sounds brighter and more aggressive :) And to cover the rest of the hole i just ordered a new pickguard
  7. boris bubbanov
    New Orleans, LA + in the
    I'd replace all the components in the control plate. Ensenada accepted those from an outside contractor, whole control plate assemblies done over in Asia and I just don't find that they're up to par.
  8. boris bubbanov
    When I first put together a new project, I run the bridge pickup directly to the jack. To learn the basic personality of the new guitar; the nature of it. But eventually, in order to actually use it, I run the signal through the control plate - provide a means to bypass the pots through the blade switch.
