Mod to Tame the highs on a Crybaby?
Discussion in 'Burnt Fingers DIY Effects' started by tacomamc, Jul 30, 2014.
  1. tacomamc
    tacomamc Tele-Afflicted
    Northeast Pa
    I Have a run of the mill crybaby, was bone stock. I did the true bypass mod and vocal mod (forget the actual resistor values) and removed the buffer stage. The problem I'm Having at the moment is that when I engage the wah, the trebles are crazy present, rip-your-soul-in-half present. I'm playing a strat copy into a red stripe peavey envoy. What do you suppose I can change in the wah to tame those highs?
  2. bricksnbeatles
    bricksnbeatles Tele-Afflicted
    Long Island, NY
  3. tacomamc
    Northeast Pa
    Ya know, I actually forgot about this trick when I started this thread. I appreciate the reminder.
  4. bricksnbeatles
    Long Island, NY
    No problem, glad to help.
  5. notyalcer
    notyalcer Tele-Meister
    I modded an old Dunlop wah with a regular guitar passive tone control circuit at the output jack. A 250K pot with a .22uF capacitor, to ground. You can then roll off the highs and limit the top end of the wah, mellowing it out as much as you need. Because its placed after the way circuit, it has a stronger effect than using the tone control on your guitar. It worked pretty well.
    I think the Jerry Cantrell wah uses this method.
  6. tacomamc
    Northeast Pa
    Hey, that's a great idea.... Pretty simple, it would seem.
  7. jipp
    jipp Friend of Leo's
    apache junction az
    where did you mount the pot, to the side?
  8. notyalcer
    Yes. Drilled a hole in the side of the housing. It was an old 1980s era wah that became a mod/experiment platform. I tried most of the mods found around the internet. Even added a switchable buffer. It sounded good, but I was having trouble with the true bypass switch engaging. Eventually I got a Fulltone Clyde Deluxe, which has a much wider more controllable throw on it, and really haven't used the old one in a while.
  9. Joe Gagan
    Joe Gagan Tele-Meister
    Albuquerque NM USA
    notyalcer,
    a 250k tone control at the end of circuit affects the wah sound quite a lot in a wah with no output buffer. the 250k pot/tone cap ends up in parallel with the outer lugs of the wah pot, effectively rebiasing the whole wah. if it sounds good, it's ok, but just a warning to people reading this , it may or may not work in your wah ( many wahs, it will hurt the tone of the wah in my experience both in LT Spice simulation and real builds.)
    the cantrell pot on the side of the dunlop sig wah is a 5k pot that interrupts the ground connection at the wah pot, changing the highs emphasis. a nice mod by the either sam macrae or jeorge tripps.
  10. Joe Gagan
    Albuquerque NM USA
    to tacomac, you can try putting a simple cap across your pot lugs -- output lug ( blue wire ) to ground ( black). some dunlop bonamassa wahs have a 330 pf for a mild highs reduction, for more radical high rolloff you can go as high as 2200 pf ( aka .002 uf)
  11. tacomamc
    Northeast Pa
    Joe, thanks for your input, I'll try it next time I've got my soldering iron fired up
  12. Sandia Man
    Sandia Man Tele-Meister
    Albuquerque, NM
    Cool! I just tried this with a overly crispy sounding crybaby and it works toot sweet
    Went with a small trim pot inside the case rather than drilling a new hole for a side mount
    Excellent modification
  13. Bill Moore
    Bill Moore Tele-Afflicted
    Silver City, New Mexico
    The last one I experimented with, I did the usual tone mods, and true bypass, but installed the 470K pot used in the Jimi wah, and a red fasal inductor paralled with a .o22 cap. Very midrange tones, (I even dialed the gear as far as possible to the treble position). I may experiment with a variable pot on the next one.
      File size:
      51.3 KB
      200
