Mod to a Dano
Discussion in 'Shock Brother's DIY Amps' started by Prophetsnake, Oct 2, 2019.
  1. Prophetsnake
    Prophetsnake Tele-Meister Silver Supporter
    ireland
    So I am getting into this project now and am running into a few new things - which is nice.
    The circuit on this thing is simple enough, but it's a bit different from anything I've done before.
    Anyhow, I'm leaving the tremolo out altogether, and it seems to me that the coupling caps downstream of where it would have been injected are redundant. Of course, if I remove them and the two 390k resistors, then the value between the phase inverter and the output tubes changes. Would simply halving the value and installing only one do the trick? And would I leave the remaining two 390k at their original value?
    I'd also welcome, any other observations on this circuit.
    https://el34world.com/charts/Schematics/files/Danelectro/Dano_special.pdf
  2. shortcircuit
    shortcircuit Tele-Meister
    North Carolina
    With the tremolo circuit removed, and the second set of 390K resistors grounded, what you have there is a second order high pass filter with the -3dB frequency at 40Hz. Removing the extra 390K resistor and 0.01uF cap will not affect the roll-off frequency, only make the drop-off less steep.
