Mod suggestions for push/pull pot
Discussion in 'Tele-Technical' started by Mr. Shred, Jul 21, 2011.
  1. Mr. Shred
    Mr. Shred TDPRI Member
    Finland
    Howdy there fellas!
    I've been thinking about replacing my standard volume pot with a push/pull pot but I've run out of ideas of what to do with it.
    These are the mods I've already got in my Tele (well 3. and 4. aren't quite finished yet), so there's no point in suggesting any of these:
    1. Out-of-phase
    2. Blower
    3. Arlo cocked wah
    4. Pickups in series (big thanks to Phostenix on 3. and 4.)
    5. Killswitch
    Both of my pickups are singe coil so there's no need for coil-splitting.
    I'm always looking for ways to expand my Telecaster's sonic qualities, so feel free to suggest any push/pull mods you can think of.
    Thanks in advance,
    Mr. Shred
  2. Phostenix
    Phostenix Tele-Afflicted
    Phoenix, AZ
    How are you doing 1,2 & 5 now?
  3. Mr. Shred
    Finland
    1. & 2. are separate mini switches located between the volume and tone pots and 5. is the Shadow Kill Pot. The mini switches are connected to the pickup selector switch by jumper cables just the way the pickups would be. So when the switches aren't being used, the pickups just run through the DPDT switches into the pickup selector.
  4. Phostenix
    Phoenix, AZ
    I'm only coming up with 2 ideas of the top of my head.
    1. Wire it to change the tone cap (different value or type)
    2. Wire it to put something like a .001uF cap in series with the Neck pickup. That will will you a thinner sound from the Neck pup in its "normal" connections & the Half Out of Phase connection when you reverse phase the Neck pup in the middle position (both pups in parallel). I really like the HOoP tone. Are you reversing phase on the Neck pup now?
  5. garrett
    garrett Tele-Afflicted
    Just south of Tampa Bay
    Number 2 is a great idea. I love the half out of phase tone. I use a 0.01 uf cap. The bass/mid cut when on the neck pickup alone can be handy, especially if you have a fat sounding pickup.
  6. Mr. Shred
    Finland
    Yes, my switch is reversing the neck pickup's (DiMarzio Twang King) phase.
    I might just try that (Phostenix's suggestion #2) out if nothing more useful or intriqueing comes up. If I decide to go with that I'll probably be needing some wiring diagrams, since my electronics skills limit to only following instructions.
    In the meanwhile I'm still open for any suggestions...
  7. Mr. Shred
    Finland
    C'mon guys! Only two suggestions so far (the Half-out-of-phase is a good one though). Can it really be that there are no more tonal mods for my Telecaster?
  8. garrett
    Yeah, I think you've nearly done it all!
    Maybe you should get a Q-Filter from Bill Lawrence.
  9. honeycreek
    honeycreek Tele-Afflicted
    OH
    My favorite use of a push pull in one on my guitars is as a disconnect on the tone pot that also makes the tone pot become a blend for the middle pickup. Basically, it moves the tone pot from being connected to the capacitor to being connected to the output of the middle pickup. As you turn the knob back, it adds in output from the middle pickup which is a great effect with a lot of usable tones. If you don't want to add the middle pickup (Nashville configuration), you could still make it blend in the neck pickup. I use the tone pot as the push pull though...
  10. Mr. Shred
    Finland
    Okay, thanks guys! I think I'll go for the HOoP mod after all. Since my Tele is a two pickup guitar the blender pot wouldn't probably reach its full potential with my setup. Now I'll just have to wait for the parts to arrive, so I can get modding again.
  11. RandomUserName
    RandomUserName Former Member
    Atlanta, Ga
    Active electronics?!?
  12. honeycreek
    OH
    I had "half out of phase" in one of my guitars for a while...definitely worth trying.
  13. PaddyWagon
    PaddyWagon Tele-Meister
    Huntington Beach, CA
    I hooked up a two pickup guitar with serial or parallel wiring between the two on the push-pull pot, definitely a different feel.
  14. craigoslo
    craigoslo Tele-Meister
    oslo, Norway
    I'm not sure if this is what Blower means, but a vol/tone bypass is the best mod I've ever done. (That and series/parallel)
  15. avagadro
    avagadro Tele-Meister
    Prescott
    I've tried pickups in series and it worked good on one guitar not so good on another. I think it depends on how much "hair" the pickups already have, if the pickups are pretty hot they get kind of muddy in series, at least that's how I hear it. How about a Lawrence Q filter? I've been thinking of going the push/pull routine with one of them, around $30 dollars plus shipping.
  16. Mr. Shred
    Finland
    Yes craigoslo, Blower switch connects the bridge pickup straight to the input jack bypassing the rest of the guitar's electronics.
    I did look into the Q Filter and I might have bought one if the shipping costs to Finland weren't so ridiculous. I haven't found any Q Filter dealers in the EU, so I think I'll have to pass that one unless someone points me in the right direction.
  17. Mr. Shred
    Finland
    Quess I'll go for the HOoP mod after all. Thanks for your suggestions guys!
