Mo’s 2020 Brotherhood Build (maybe)
Discussion in 'Tele Home Depot' started by mo62987, Mar 17, 2020.
  1. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    Good to see you jumping in Mo :).
    The more, the merrier!
    mo62987 and crazydave911 like this.
  2. mo62987
    mo62987 Tele-Meister
    B'ham, AL
    I hope all you folks with bandsaws appreciate how good you have it :D
    And I hope at some point you have experienced the joy that is trying to cut a 1.75” thick hunk of hardwood with a crusty ol jigsaw (Or whatever other tool you can find in the shop).
  3. LeftFinger
    LeftFinger Friend of Leo's
    The Land of Plenty
    The Mo the merrier
    "And I hope at some point you have experienced the joy that is trying to cut a 1.75” thick hunk of hardwood with a crusty ol jigsaw (Or whatever other tool you can find in the shop)."
    I had a plastic black&crapper I tried that with. The innards of the thing came out the side :eek:
    a tip you may already know
    drill some holes in the inside curves;)
    2blue2, mo62987 and crazydave911 like this.
  4. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    All I got is a jigsaw. Serves me well!
    2blue2, crazydave911 and mo62987 like this.
  5. eallen
    eallen Friend of Leo's
    The blade used makes all the difference! The bosch T234X is the best I have used back in the old days of pre bandsaw.
    Great build.
    Eric
    crazydave911 likes this.
  6. mo62987
    B'ham, AL
    yikes!
    And yeah I drilled the inside curves
    Probably could’ve gone a little closer though.
  7. mo62987
    B'ham, AL
    @eallen yeah I started with a fairly dull blade and hard a rough time. Once I changed to a new blade it went much better
    crazydave911 and eallen like this.
  8. mo62987
    B'ham, AL
    Little bit everyday...
    the next step terrifies me so I got myself right with the Lord and got my affairs in order then hit the outside of the body with the router
    got the first pass all done with the back template on. Before I moved on, stopped to get the back trem route. Got about halfway in so far
    Macrogats, 2blue2 and crazydave911 like this.
  9. eallen
    Looking good. Just fyi, that's a dangerous amount to remove with a router for kick back and tear out. When routing I think shaving. A beard takes scissors first [emoji16]
    Eric
  10. mo62987
    B'ham, AL
    haha yeah I know... this took many light passes. The jigsaw just doesn’t quite get me to the line. As I mentioned above - this is a scary step. (An O.S.S. is on the wishlist :cool:)
    Im extremely aware of where everything is at all times. With other power tool use, I feel like I have a healthy respect/fear for the tool. At least enough to keep all my limbs and digits. But the router table is a whole different ballgame.
    eallen and crazydave911 like this.
  11. Jim_in_PA
    Jim_in_PA Friend of Leo's Silver Supporter
    SE PA near New Hope PA
    This is absolutely true with a jigsaw, even one that doesn't have the more advanced guides like the Bosch and Festool.
    crazydave911, mo62987 and eallen like this.
  12. mo62987
    B'ham, AL
    Slow and steady win the race with a jigsaw too!
    Had a few minutes today to finish up the rear trem rout.
    Macrogats, E-miel, 2blue2 and 3 others like this.
  13. guitarbuilder
    Just so you know, that's too much wood left to pattern rout off without getting tear out, or worse having it fly across the room. It should be about 1/32".
  14. mo62987
    B'ham, AL
    I agree that I left too much meat for routing. Alas, deed is done. Many passes of 1/32” ;)
    Macrogats, E-miel, Jim_in_PA and 4 others like this.
  15. 2blue2
    2blue2 Friend of Leo's
    Island of Oahu
    I'm doing the same NoBandsaw and NoOSS approach.
    I guess lack of tools and common sense ~ don't outweigh desire and determination.:eek:
    That Body blank is looking good now though right!?!
    Yes it is.:D:rolleyes::)
  16. mo62987
    B'ham, AL
    Started hogging out the cavities
    E-miel, Jim_in_PA and crazydave911 like this.
  17. mo62987
    B'ham, AL
    Control and jack cavity routed down to depth
    Macrogats, E-miel, paulmarr and 2 others like this.
  18. eallen
    Looking good!
    Eric
  19. mo62987
    B'ham, AL
    Neck pocket day
    Pretty good... I made all the templates by hand so there’s a tiny bit of slop. But I’m happy with it.
    Then on to the swimming pool.
    RodeoTex, E-miel, paulmarr and 2 others like this.
  20. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    I put one layer of thin tape around the routing surface of the neck pocket template to make it just a bit smaller. If the neck is too tight then I sand the neck. You don't want it too tight as the finish will help fill it in.
    Looking great!
