mmoncur's 2012 Challenge Build Thread -- COMPLETED
Discussion in '2012 TDPRI Tele Build Challenge' started by mmoncur, Mar 14, 2012.
  1. mmoncur
    mmoncur Tele-Meister
    Salt Lake City
    Started smoothing the edges on the ROSS. My bandsawing was sloppy so I had to remove lots of material, but it's still easy. Note the cool random square pattern the yardsticks create on the side, and the subtle blue stripes are all that remains of the inch markings.
    Also started on a neck. Here's the truss rod channel... one yardstick was sliced before gluing to avoid having to use a router.
  2. mmoncur
    Salt Lake City
    Finished the body on the ROSS today.
    The spindle sander is a lot less forgiving of sloppy bandsawing than the belt sander. I had as much as an inch of extra material to remove in some spots, and the belt sander made it easy, but it took about 20 minutes with the 3/4" spindle to finish the inside curves.
    I'm not going to rout the body or even do a roundover, since I'm still scared of ruining it with the router and I don't have time for repairs. It's a thin guitar anyway, so I'm just going to round the corners manually with a sanding sponge. I've already started in the pictures.
    I also hollowed out the control cavity. I had to remove 1.25" to fit my low-profile switch, leaving only .25" of guitar at the back, and one router slip would mean a hole in the guitar. So I hogged it out gently with a forstner bit and finished with a chisel and file. It's a bit sloppy but the control plate will cover it...
    (I moistened it a bit for these pictures to show the wood color. I'm going to do a natural tru-oil finish so it will look pretty much like this!)
  3. Allthesound
    Allthesound Tele-Afflicted
    Connecticut
    Looking good keep at it!
  4. fretman_2
    fretman_2 Friend of Leo's
    Mobile, AL
    The body looks a little like bamboo. Great build so far.
  5. guitarbuilder
    Hey...great idea...I love this one!
  6. Picton
    Picton Friend of Leo's
    Reading, Massachusetts
    I do my roundovers with rasps, files, and sandpaper. It's a less agressive approach if you're afraid a router will get away from you (I always am).
    Looks good!
  7. mmoncur
    Salt Lake City
    Here's the neck in progress...
    And a fretboard in progress.
  8. mmoncur
    Salt Lake City
    Cutting the neck down to the right thickness... First poorly on the bandsaw.
    Then cleaned it up on the ROSS.
  9. Jupiter
    Osaka, Japan
    Your router is starting to think you hate it. . . . ;-)
  10. mmoncur
    Salt Lake City
    I don't hate the router, I just fear it... Especially since I took a chunk out of my neck pocket template and a chunk out of my workbench when I did the cavities. So I'd like to learn to use it properly before I trust it with the most visible parts of a guitar...
    Meanwhile, on the fretboard. Here it is sanded, showing a jig I made haphazardly using a pre-cut fretboard I had handy, a square, a ruler, some clamps, and some double-stick tape to mark the locations of the frets.
    Frets marked.
    Finally I used the square and a Harbor Freight pull saw to cut the fret slots. I'm just guessing at the depth at this point, but they seem lined up pretty well so far.
  11. Picton
    Keep pluggin; this is fun to watch. I'm living proof that you can do this enjoyably without a router, though it's needed for a trussrod and nice to have when you're binding. Other than that...
    Nice FB.
  12. mmoncur
    Salt Lake City
    Lots of progress last night, but not much time to post pictures. Here's a test fit of the bridge, pickups, pickguard, and controls...
    (with a borrowed neck)
  13. mmoncur
    Salt Lake City
    OK, the body is finished, aside from wiring. Here are the final pictures:
    Drilled holes for wiring using a ridiculously long 25" Harbor Freight drill bit. I thought the extra length would make it difficult, but it actually made it really easy to line up and kept the drill far from the guitar body.
    Routed (With extreme trepidation) the neck pocket a bit deeper. The neck was a bit high before, room for 2-3 pickguards. No problem at all.
    Drilled a 7/8" hole for the output jack with a forstner bit. THAT was scary! It took about 10 minutes and I don't like how close it came to the top of the guitar, but everything's fine. I also drilled a hole from the control cavity to the bridge pickup through that hole.
    Finished the body with two coats of Birchwood Casey sealer and filler, sanding with 220 and 400 grit in between, and a thin coat of tru-oil. I might stop right here, I like the satin finish and the grain showing. (Tru-oil is still wet in the picture, it won't really be quite this shiny!)
  14. junk mutt
    junk mutt Tele-Meister
    Englandland
    Looks great! Keep it up, your almost done.
  15. mmoncur
    Salt Lake City
    Neck progress...
    Testing the fretboard placement. I also traced a rough headstock shape from a neck I had lying around. HUGE MISTAKE - it was a 24.75" conversion neck. Almost made the headstock an inch short. I should probably print a template before I finish this neck.
    Attached a piece of yardstick to the fretboard end to mark the lineup of the 22nd fret extension with the neck.
    Truss rod test. It works!
    Gluing on the fretboard. This didn't work extremely well, I had to re-clamp each side later because it separated a bit at the edges. I think it will work though.
  16. mmoncur
    Salt Lake City
    By the way, thanks for all of the encouraging words! I'm amazed I've made it this far, and I think I can finish by the deadline! Keep your fingers crossed.
  17. mmoncur
    Salt Lake City
    OK, I printed a template for the headstock and the nut location and stuck it on. In retrospect I wish i hadn't done that because it took half an hour to remove the adhesive from the fretboard later.
    Rough cut the shape on the bandsaw.
    ...and started to shape it on the belt sander.
  18. mmoncur
    Salt Lake City
    Headstock thicknessed (also on the ROSS) and spindle sanded to be a bit more Tele-shaped.
    Radiused the fretboard and started installing frets.
  19. Allthesound
    Connecticut
    Hurry!... No pressure :D
  20. Sasz
    Sasz Tele-Meister
    You've got an amazing amount done in the last few days!
    Fingers duly crossed for you :cool:
