Minimum Body Thickness Question (POLL ADDED)
Discussion in 'Tele Home Depot' started by zcostilla, Jan 18, 2020.
Is a 1 1/4” slab of salvaged spruce thick enough for a guitar body
  1. Yes, it will work fine if the heel is done right
    17 vote(s)
    77.3%
  2. Yes, but only with a shorter scale length (i.e. Mustang or Duosonic)
    1 vote(s)
    4.5%
  3. No, it will fail under the strain
    4 vote(s)
    18.2%
  1. zcostilla
    zcostilla TDPRI Member
    St Louis area
    Question? If I built a body from scratch, that’s the minimum thickness I should go for?
    I was given a 100-year old piece of spruce planking at 1 1/4” thick and 24” wide, lacquered on the front and back. It’s tongue & groove from an old pipe organ air box. I’m building a lap steel from it but still have a 38” long section. Thought about a super lightweight bolt on, in a Tele shape, but it doesn’t leave a lot of meat for the neck joint. Thinking I might plane it to 1” and put a thin cap, and if I go that route, I’ll probably chamber it to make more weight savings. But if you think I could go this thin, it would be neat. Might have to take 1/4” off the neck heel thickness and use shorter screws to make it work. I’ll be using a Hipshot hardtail bridge I already have in my spare parts box.
    crazydave911 likes this.
  2. bender66
    on my bike
    I dont think I've seen anything thinner than 1.5"ish, but theres prob one somewhere.
    Why not just sandwich it to 1.75"?
    zcostilla and radiocaster like this.
  3. Mike Simpson
    Gilbert, AZ (PHX)
    I have done 1.4" but the control cavity bottom is very thin and you have to bend the bottom tabs on the switch up. I made the guitar out of 2x4 from a pallet. It is the depth of the Tele switch that limits how thin you can go. You can do 1.4 or maybe less if you use a Gibson type switch like on a Cabronita.
    Bergy and zcostilla like this.
  4. zcostilla
    St Louis area
    So if I went one pickup, like an Esquire, and eliminated the switch, do you think the neck pocket would hold up?
  5. Mike Simpson
    Gilbert, AZ (PHX)
    I routed a .625 deep neck pocket in a Couple of 1.4” thick pine bodies and had no problems.
    zcostilla likes this.
  6. jimgchord
    jimgchord Tele-Afflicted
    victor,ny
    Im confused. 1/4" and you want to build a solid body?
    crazydave911 and zcostilla like this.
  7. guitarbuilder
    Body thickness depends on switch use. SG's were around 1-3/8" thick with the SG style toggle. Hagstroms may have been thinner due to slide switches. The other thing to consider is control depth and neck cavity depth. A typical F body has about 1-1/8" of wood under the neck. You could go lower, but as you get thinner there the chance of flex is greater...again Think of an SG. There are bolt on SG bodies out there with probably 3/4 or even less wood under the bolt on neck. It depends on the wood species too. A denser wood would yield less flex than a less dense wood might.
    You can see how thin this Hagstrom neck cavity is if you scroll through the pictures.
    https://reverb.com/item/29405601-ha...tar-baby-blue-1960s-needs-work?show_sold=true
    PingGuo, crazydave911 and zcostilla like this.
  8. Jim_in_PA
    Jim_in_PA Tele-Holic Silver Supporter
    SE PA near New Hope PA
    I believe the OP meant it to be 1.25" (1 1/4") but fat-fingered it.
  9. Jim622
    Jim622 Friend of Leo's Silver Supporter
    Philly
    My main problem is body thickness also.
    Jackadder, crazydave911 and zcostilla like this.
  10. jimgchord
    victor,ny
    Ahh...the ol fat finger.
  11. zcostilla
    St Louis area
    This is exactly what happened. Sorry. I corrected my OP.
  12. zcostilla
    St Louis area
    Thanks for the Hagstrom comparison. The fact that it’s spruce was also my concern. It is a lot denser than soft pine you find in the lumberyard, but it’s also definitely not quartersawn.
    Zac
  13. guitarbuilder
  14. zcostilla
    St Louis area
    Mr_Q likes this.
  15. zcostilla
    St Louis area
  16. zcostilla
    St Louis area
    Weight is a big factor for me, because I have spine, knee, and shoulder injuries from my military service. I pretty much have to play sitting down if I play more than one song, unless I’m using my Godin 5th Avenue. It’s the only guitar I own that’s light enough to play standing up for any length of time, but I have it set up as a jazz box (D’Addario chrome flatwound strings and a custom Charlie Christian pickup).
    Also, I added a poll to collect responses. Please keep the feedback coming. You guys are great!
    bender66 likes this.
  17. Mike Simpson
    Gilbert, AZ (PHX)
    When making anything non standard, it is a good idea to get the switches and hardware you want to use and have them on hand when making the body.
    bender66 and zcostilla like this.
  18. guitarbuilder
    You could always make a shallower neck cavity and use a taller bridge...like a Gibson ABR-1 type too. Those are about 5/8" tall as compared to a tele bridge at 3/8" tall.
    Mr_Q and zcostilla like this.
  19. Mike Simpson
    Gilbert, AZ (PHX)
    This body is pine about 1 7/16 or 1.4 thick. The bottom of the neck pocket is just under 3/4 thick. Played hundreds of gigs in all kind of temperatures, no problems.
  20. bender66
    on my bike
    That's why I thought about sandwiching 2 pieces. Bottom piece your full thickness (1 1/4") fully routed out minus your crucial areas, & the top piece the appropriate thickness planed down (1/2"?) gives you a light full size tele of 1 3/4", or however you want to achieve the proper width.
    Like these, specifically the tele, before your cap.
    tnt423, Jim_in_PA and zcostilla like this.
