Mini toggle stout enough?
Discussion in 'Shock Brother's DIY Amps' started by Mark the Moose, Dec 29, 2019.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    Adding a NFB switch to a Princeton Reverb, will a mini toggle hold up or do I need something heavy duty?
  2. BigDaddy23
    BigDaddy23 Tele-Holic
    They worked for me in my deluxe and a couple other amps - nil issues thus far
    Mark the Moose likes this.
  3. Mark the Moose
    Erie, CO
    Same question regarding a 4/8 ohm impedance switch?
  4. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Yes in both cases.
    A NFB works on tiny currents. You could use anything rated half a watt or higher.
    In the case of a speaker loop it works in watts but not very high voltage.
    A toggle rated 125vac would be fine.
    Mark the Moose and BigDaddy23 like this.
  5. nojazzhere
    Foat Wuth, Texas
    The only issue I'd bring up is, I've used a couple of mini-toggles on my guitar for pickup selectors, and the cheaper ones don't hold up to repeated use......buy the top quality ones.
    robrob, schmee and Mark the Moose like this.
  6. Mark the Moose
    Erie, CO
    I have a crap ton of mini toggles from building pedals but would have to order the big ones, so I was hoping to avoid a week-long delay.
  7. trev333
    Coolum Beach,Australia
    this cheapy has held out for @8 yrs ..so far, so good...:D
    how often do you use an NFB switch?.... ;)
    Skydog1010 likes this.
  8. Skydog1010
    Skydog1010 Tele-Afflicted Platinum Supporter
    North Carolina
    Yeah they work well, actually better than most LP style three ways. I will say that all of my minis have been spst (on/off).
  9. telemnemonics
    I’d use a pot for the nfb.
    Wally and jtcnj like this.
  10. SacDAve
    SacDAve Poster Extraordinaire Silver Supporter
    Rocklin Ca.
    I use the mini toggle on my amps for NFB switch there fine, advice stay away from cheap ones on amazon
  11. Pick_n_Strum
    Pick_n_Strum Tele-Meister
    Lino Lakes, MN
    Mini toggle has held up great in my 5e3 - although it is still young yet.
  12. King Fan
    Salt Lake City
    I don't know about duty cycle durability, but for impedance switching I'd fit a rotary switch like Rob and many others do -- toggle switches are way too easy to set or leave or bump into the 'wrong' position. This isn't a switch you use that often, so can easily and usefully be stuck somewhere on the back of the amp.
    FWIW, I seldom use my NFB switch, and I've seen more than a few PR owners say the same thing. But for related reasons I do like the idea per @telemnemonics to use a pot -- a little bit of a cut is a lot on a PR, and you may want to adjust with precision.
  13. Wally
    The Prin Rev feedback circuit does not have as much cancellation effect as do the loops on the larger Bf/SF amps. I have never modded a Prin Rev NFB loop, but if I did I would be using at least a 10K pot in series with that 2700ohm top resistor.
    I also have never used a switch as I prefer adjustability. Nuance, nuance, nuance....
    I know one fellow who used the pot I installed for him to ‘tune’ the amp to the room. If he was in a cold, hard surface venue; he went large on the resistance. If he was in a warm room, he tended to go closer to the stock resistance.
