Mighty mite pickup wiring
Discussion in 'Tele-Technical' started by rotheryrules, Dec 9, 2012.
  1. rotheryrules
    rotheryrules Tele-Meister
    Manchester Uk
    So it's not a tele, but im swapping the pickups in my squier bullet to Mighty Mite dual coil humbuckers.
    My problem is that the MM pickups have a Completly different wiring colour to any other I've seen and the Internet isn't really helping!
    Help!
  2. sjtalon
    sjtalon Doctor of Teleocity
    Upper Peninsula of Michigan
  3. rotheryrules
    Manchester Uk
    Ah fantastic, many thanks!
  4. rotheryrules
    Manchester Uk
    All in and working now
    I always presumed there would be loads of mighty mite diagrams on the net!
  5. sjtalon
    :D
    How does it sound now with that pup ?
    Happy pickin'
  6. rotheryrules
    Manchester Uk
    That is a good question, in short am not sure!
    I've got an issue with phase on the neck and middle pickup, when I coil tap either they sound horrible. The bridge pickup sounds great full hb or coil tapped!
    I do like the pickups, not sure if they have removed to much strat tone from the guitar, which is why I wanted the coil tap.
    I will investigate and try and determine why the coil Tap isn't working as it should, not sure if they will stay in, depends if I can fix the gremlins!
    Looks great though!
